repairing a plactic bumper
Started by phill osey, 29 November 2012, 00:31:58
phill osey
does anyone know if its possible to repair a  rear bumper on a VW Passat, instead of having to replace it
Someone ran into the back of Phils car, and the bumper is cracked on the drivers side right on the curve against the tailgate
is a repair possible, if so, any ideas about how to go about it?
Thanks
Lee
love my Omega
Google plastic welding outfits in the local area.A good one can almost perform miracles with broken plastic.  :y
phill osey
love my Omega
Can work wonders with an old soldering iron and some Isopon ::)
when the plastic welding job is finished.. sand the surface roughness.. 220-320 (dry or wet)
use plastic primer..  then normal primer.. again sand it..  500-800..
then paint..  will be perfect.. :y
ps: normally I'm against bondo as later it creates problems..  if necessary you can use a tiny layer but you need to let it dry for few days..
phill osey
Thanks all will get Phil to look at these suggestions whe he gets home tonight  :y
Lee
love my Omega
