Audio Problem
Started by Ninda, 29 November 2012, 09:48:22
Ninda
Hi guys, i have asked this question before but i cant find it :(
So ill start over again, i have a 3.2 Elite, well it was my dads but now its mine :D, and well i have replaced the Headunit with an Aftermarket Headunit, and i have lost all sound. I was told i need to change the amp and replace some speakers, now if i replace the amp and the speakers will all the other cars speakers work is well? As right now i have no sound what so ever. Also which speakers do i need to replace?
Please and Thank You
Brikhead
Quote from: Ninda on 29 November 2012, 09:48:22
http://www.omegaowners.com/forum/index.php?topic=108516.msg1358634#msg1358634
You'll need to replace all the speakers as they are 2 ohm, aftermarket stereos start at 4 ohms.
You'll also need to modify the wiring in the car.
Ninda
Ahh thanks Brikhead, it says that i should start a new thread, so i guess ill just talk in this thread.
Ok Tunnie i will have a read over that, but i got a quick question, Does anyone know what speakers exactly i have to change?
Sorry for being a pain.
Quote from: Ninda on 29 November 2012, 19:59:41
All of them  :y
Brikhead
As said, you need to change all of the main speakers in your car,
you have two in the front door and two in the rear door.
Being as you have an Elite with the Bose sound system you should have an extra two speakers on the rear shelf.
All of these speakers are wired into the 2 ohm Bose amp.
You need to sort out the wiring before you change the speakers or you risk burning out your headunit...
Just replace the original headunit or a like for like unit ........ far easier in th end. And if you must be able to play mp3s etc use a FM modulator  :y  :y  :y
Brikhead
Quote from: Andy B on 29 November 2012, 21:11:37
Like for like won't work with the screen fitted to 'Nindas' car...
Quote from: Brikhead on 29 November 2012, 21:16:09
You know what I mean .........  ??? A N Other will fit/work provided it's divorced/etc
