Pages: 1 2 [3] 4 5 6   Go Down
Author Topic: Odd temperature behaviour  (Read 10046 times)
Re: Odd temperature behaviour
« Reply #30 on: 29 November 2012, 21:42:08 »
Still think it's the stat and it makes me think I need to sort mine sooner rather than later ::)
We could do some back to back runs Sunday am and compare yours vs mine if you like? :-\
« Reply #31 on: 29 November 2012, 23:25:33 »
The thermostat looks like it is the prime suspect  ;D
I'm not convinced.. Unless the vapouriser (different to mine) is a lot less efficient at getting heat into the gas. :-\
« Reply #32 on: 29 November 2012, 23:27:23 »
It does seem strange... I know my car is overcooling but it still switches over to LPG and runs fine at 30C (I think) :-\
Thinking about it... That Vap has been out since the first fit and temp sensor re-wired... I wonder... :-\
« Reply #33 on: 30 November 2012, 10:09:20 »
It is also mounted with the coolant feeds at the bottom, so I can see that it might be prone to airlocking, and it would be unlikely to fill completely with coolant. Then again, guessing you and theboy both have exactly the same setup without any issues? :-\
« Reply #34 on: 30 November 2012, 13:02:23 »
I've purposely staying out of this because I have an cold idle/stall problem on my Omega with the same setup (TBE), so I think my experiences would confuse the issue.
Beyond the cold idle problem, mine behaves as you would expect, except the gauge overshoots as it warms up, then drops down as the stat opens, then goes to where it should. Probably slightly slow to open the stat.
Idle problem is known about, that Cripple bloke has some new nozzles for me, as 2.5mm is WAAAAYYY to big for this setup  :-[
« Reply #35 on: 30 November 2012, 13:33:33 »
Oh yes... Must put them in the car :-[ ::)
I have the same vap setup and (known stat issue aside ::)) mine doesn't seem to drop temp too much :-\ :-\
Mind you... I had a load of missfire codes this morning ::)
« Reply #36 on: 01 December 2012, 05:23:07 »
Well, I find if I leave the car to warm up on frosty mornings before I get in it, I don't have a problem. :y
« Reply #37 on: 02 December 2012, 00:14:43 »
Needs some live data from the LPG system to see what's going on when it's playing up, IMHO.
« Reply #38 on: 02 December 2012, 16:11:56 »
Changed temp sensor setting to one the same as Lazydockers. Now reads a figure about 40c higher, and similar to engine temp.
No idea if that makes any odds or if the software will react differently to a higher figure, but I'm going to try it on the new setting for a couple of days.
Obviously the exceptionally cold weather has no baring on this at all. ::)
« Reply #39 on: 02 December 2012, 16:51:45 »
Ahh, well, if the sensor was telling us porkie pies... ;D
Not sure it will help that much, as I think that temperature is only used for switchover criteria. Don't suppose the vapour temperature sensor is wrong too?
« Reply #40 on: 02 December 2012, 17:31:44 »
It would explain the apparent difference between vap and coolent temp though, and although it did dip on wot at similar speeds, it's was nowhere near as close to switch over point as we might have thought.
So might dispell the air lock theory.... But not the rough running...?
« Reply #41 on: 03 December 2012, 20:55:39 »
Nope, that made bog all difference.
Still plays up badly between 65 and 80c engine temp.
« Reply #42 on: 03 December 2012, 22:55:46 »
With climate panel on today?
Try without tomorrow as it behaved yesterday with it off :-\
Very curious though as there was nothing obviously wrong :-\
« Reply #43 on: 03 December 2012, 23:00:33 »
Set to 27 from the off.
See what the weather is like in the morning. ;)
  • Auckland
    • Mazda MPV
« Reply #44 on: 04 December 2012, 08:09:15 »
If it worked OK with climate turned off (and if climate 'off' means that the HBV switches to bypass the heater matrix) then that points to resistance from the heater matrix causing reduced flow IMO.
Pages: 1 2 [3] 4 5 6   Go Up
