Author Topic: alarm? weirdness after car wash  (Read 1358 times)
MaxV6
  • Oxford UK
    • 2.2SportPremium Jag est
    • Work related forums....
« on: 29 April 2008, 22:14:43 »
So there i am, take the elite thru the fancy car wash by tescos...   the all singing all dancing, full works programme...   get rid of that morning's bird crud...    all fine and cool and froody,  drive off and fly off along the dual carriageway...
about 10 minutes after leaving the car wash, braking on the approach to a roundabout, a high pitched siren/beeping thing goes off... sounds a lot like the alarm power sounder thing on the sintra did when disconnecting the battery without disarming the alarm system first...  (actually, the old miggy also did that, but it sounded different.. )
no lights flashing internally, obviously i've no idea if they were doing so externally....  ,. It went on for a few minutes, till i could safely stop the car, get out, lock it, unlock it, and restart it...  then drive on...
then , under braking again, abolut 10 minutes later it did it again, just briefly, and stopped....
WHAT THE break WAS THAT ABOUT????
Now I think I keep hearing odd little electrical noises , arc'ing, buzzing, etc...   just now and then...
is there some leaky point on late mini facelift eleite estates I'm unaware of??   and some vulnerable bit of expensive electrical trickery??
the old car never did this....
I'm officially worried.....
Re: alarm? weirdness after car wash
« Reply #1 on: 29 April 2008, 22:16:45 »
Lol.....I have a suspicion that you have some blocked scuttle drains......your expensive car wash might just have drowned the alarm power sounder!
« Reply #2 on: 29 April 2008, 22:16:49 »
suspect the sounders got a bit soaked...
MaxV6
  • Oxford UK
« Reply #3 on: 29 April 2008, 22:27:40 »
aha !
it's in the garage tomorrow for an oil change and rear pads....    I'll be sure to make certain they're clear....      any tips and tricks?
MikeDundee
  • Costa Del Peckham
« Reply #4 on: 29 April 2008, 22:29:41 »
aha !
disconnect and smash the power sounder up :y ;D..that's what I found someone prior to my ownership had done to my omega ;D
MaxV6
  • Oxford UK
« Reply #5 on: 30 April 2008, 13:32:05 »
ouch mike....
well oil change has turned in to new sump plug....  as well....   they showed me the old , mashed up thing....
looks like something Jaime would be proud of...
