Author Topic: Any difference between preface and miniface front spring?  (Read 1750 times)
Johnny English
  • Hungary
  • English antitalent
    • 1995. 2.5 V6 LPG manual
...as above. Miggy sometimes has a strange noise especially when going through potholes . The noise comes from the direction of right front spring, which is possibly broken. Found a broken one from an also broken but miniface mig then I'm thinking of swapping them.  Any advice welcomed !
C20NE - X25XE
Re: Any difference between preface and miniface front spring?
« Reply #1 on: 30 November 2012, 08:55:49 »
What spec?
Pre-facelift springs all same, MV6/Sport on facelift had lowered springs  :y
Johnny English
  • Hungary
« Reply #2 on: 01 December 2012, 15:41:53 »
If I want miggi to be lowered just must to swap them? I mean absorbers and spring altogether.
C20NE - X25XE
« Reply #3 on: 01 December 2012, 15:48:13 »
The other spring you found is also broken though?
If you want to lower it just a tad, you might consider MV6/Sport springs and shocks from a facelift.
For a larger drop, you want to look at maybe Bilstein B4's?
« Reply #4 on: 01 December 2012, 16:31:59 »
Front springs vary with spec.
If lowering, should get away with 30mm on same shocks, though if shocks are more than 10k old, I'd replace at the same time.
Johnny English
  • Hungary
« Reply #5 on: 01 December 2012, 19:11:11 »
Not broken I'm just playing with thought  :) not sure of lowering as I often tanking in Ukraine where huge potholes there are  >:(
  thx guys !  :y
C20NE - X25XE
« Reply #6 on: 02 December 2012, 10:53:12 »
The noise could be anything, spring being least likely of all possibilitys.
Describe the noise?
Examine the car?
Don't buy broken or single springs?
You don't say what spec your car is?
Or the spec of the car the (broken?) spring is coming from?
And.... Always fit suspension components in axle pairs.
IMO, find the fault first. :y
Johnny English
  • Hungary
« Reply #7 on: 03 December 2012, 10:15:47 »
Describe the noise?
Examine the car?
The noise is creaking, my car is a 95' preface saloon GL, the donor looks like mine although can't decide preface CD or miniface CD as it's been being broken for a certain time. I examined miggy of course no bush issue ever the source of creaking suspectably is even top mount or broken spring as it is emerging at roughnesses of road such as piles and potholes. I'll sort this after christmas just need to make a plan how to finance it that's why asked.  :y
C20NE - X25XE
