Author Topic: no heat!!!!!! damsel in need of help!!!!  (Read 2124 times)
maryso
  • kent
  • car dunce....willing to learn!!
    • omega
« on: 30 November 2012, 15:24:48 »
hi everyone,
replaced the hbv in my omega and still no heat!!!! all ok under the bonnet, plenty of the stuff, but nothing coming through into car :(
could it be an airlock in radiator matrix????? been told that could be it, please help, useless female.......cold!!!!!
symes
  • oxford
    • R reg 940 volvo
Re: no heat!!!!!! damsel in need of help!!!!
« Reply #1 on: 30 November 2012, 15:50:42 »
when fitting HBV did you connect bottom heater hose AND fill (using funnel) top hose before fitting to HBV-if not you probably got air lock :y
amba
  • Medway towns
    • German V6
« Reply #2 on: 30 November 2012, 18:08:17 »
You may also have a blockage inside the heater matrix .
Worthwhile removing the 2 quickfit hose connecters at the bulk head and giving the heater matrix a flush through both ways.Covered in the maintenaince guide for hose removal
rsymes2k
  • Devon
    • 99 Omega 2.5v6 CDX
« Reply #3 on: 30 November 2012, 21:12:27 »
heater matrix unless there's no air in which case its blower issue
« Reply #4 on: 30 November 2012, 21:17:19 »
Good point.... :y  Is the heater fan blowing air?
maryso
  • kent
    • omega
« Reply #5 on: 30 November 2012, 23:52:56 »
  yes blowing air
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
« Reply #6 on: 01 December 2012, 09:08:07 »
Worth checking that the servo's are still connected to the blend flap first....
2woody
  • Northumberland
« Reply #7 on: 02 December 2012, 19:20:04 »
is the HBV connected to the wrong vacuum by any chance ?
turn up the heater control to anything above "LO" and check to see if there's a vacuum at the pipe on top of the HBV. If there is vacuum, then you've got a wrong connection.
