Dropped Brake Disk
Started by JamesV6CDX, 30 November 2012, 20:47:55
I have a new set of rear disks for the MV6.
Like an absolute plank, I dropped one, onto a concrete surface, from about waist height, whilst moving them.
Visually looks fine... but... have I weakened it? would you use, or, prefer to get a new one to sleep at night? After all, it's brakes..
Opinions welcome... :y
Being rears I'd probably stick it on :-\ :-\
If it was a front I would be a little more reluctant, but only because I sometimes like to "Use" the brakes :-X ::)
TBH, I doubt it's weakened it but that's just my opinion ;)
Quote from: JamesV6CDX on 30 November 2012, 20:47:55....
Stick it the car  ;) ;) Doubt you've even slightly damaged it from that height.
OOMV6
Quote from: Andy B on 30 November 2012, 20:54:33
Agreed. Think you'd need to give it a lot sharper blow than that to cause any damage.
by the way ........ it's a disC
Americans spell it disK  ::) ::)
Quote from: Andy B on 30 November 2012, 21:17:54
Americans spell it  disKrotoR ::) ::)
flyer 0712
If you ever saw how castings get thrown around in a foundry you probably wouldnt be worrying about it. ;)
Martian
The stress you caused the disc when dropping it is nothing when compared to the stress created when you are braking, it will be fine.
hold t up and belt it a few times on outside with rubber mallet, to ensure no fractures.
Tap them both lightly with a hammer, if the tapping produces a different tone between the two discs then the one you've dropped is cracked!
I think it's unlikely though!  :)
symes
Put it on brake rotor will be fine :y
Quote from: TiggerHayes on 01 December 2012, 10:33:03
Good idea. Not cracked will probably ring like a bell, cracked will be a dull thud.Used to test hard iron grinding plates with that method many years ago and it never failed. Rendered the relatively expensive crack testing kit redundant. :y
Of course, if it shatters when you tap it, you might want to buy another one ::)
