Author Topic: mayonnaise in oil cap question  (Read 2812 times)
SMD
  • London
    • :( nowt
« on: 02 December 2012, 14:37:57 »
After the work carried out yesterday, oil and sump change, today I noticed mayonnaise in my oil cap which I have never experienced with this car before. What could cause this?
Could it be down to not letting the silicone fully go off before filling with oil? I noticed a bit of oil and a soft silicone in one area. Can't tell if its leaking though
« Last Edit: 02 December 2012, 14:41:11 by SMD »
Re: mayonnaise in oil cap question
« Reply #1 on: 02 December 2012, 14:40:06 »
cold weather and short journeys...caused by condensation.
some oils suffer it worse that others.  gen vx is good, mobil 1 is poor for it...
SMD
  • London
    • :( nowt
« Reply #2 on: 02 December 2012, 14:42:09 »
Edited my OP
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #3 on: 02 December 2012, 15:06:35 »
Nothing to worry about  :)
Mayo is caused by water vapour / mist getting mixed up with the oil as it gets dragged threw the plenum.
Remove the cap, give it a good wipe with a rag then take the car for a good run.
As for your sump, give it a day or two longer then nip up the bolts so they are all about equal.
I've had my sump off before and never re sealed it and had no leak
« Reply #4 on: 02 December 2012, 15:27:43 »
Pull the filler off and replace cap onto rocker cover ...no more mayo  ;)
SMD
  • London
    • :( nowt
« Reply #5 on: 02 December 2012, 15:54:05 »
Thanks for all comments. That's reassuring. I need to get a 3/8"-1/4 adapter so I can torque the bolts. At the moment they are 'tight'  ::)
« Reply #6 on: 02 December 2012, 16:19:42 »
This is true. However, Mobil 1 is so piss thin that it's a good oil for a cold winter's morning. :y
flyer 0712
« Reply #7 on: 02 December 2012, 22:43:56 »
I only do short journeys and always use v.x.oil and i have never suffered with the white stuff in the cap....
dbdb
  • west london
  • Tramlining,Trade Club,WIM,my time racing,Linux etc
    • f/l elite 2.6 V6 manual
« Reply #8 on: 03 December 2012, 00:57:47 »
But where's it condensing instead?  Surely better on the fillercap where you can wipe it off than the cambox?
« Reply #9 on: 03 December 2012, 08:17:00 »
Depends on what grade of oil you use......
Abiton
« Reply #10 on: 03 December 2012, 09:06:23 »
Best if it isn't condensing anywhere, which it may well not do if you take a way the 'cooling tower' that is the filler neck...
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #11 on: 03 December 2012, 09:27:53 »
My last few oil changes have used Mobil oil the last using Mobil super 2000 I do mostly short journeys and dont get mayonnaise on the fiiler pipe, before using mobil I did. No iI bont have shares in Mobil :y
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #12 on: 03 December 2012, 09:29:26 »
Sorry bont should read dont I should add that I change oil and filter at 3000miles
kingycos2
« Reply #13 on: 09 December 2012, 12:31:27 »
I use Millers oil, its good for cold mornings but it does the same thing......... I only do 20 miles a week at the minute hence the condensation...
