Author Topic: 2.5TD injection pump removal and replacement  (Read 4614 times)
Omegatoy
  • UK
« on: 03 December 2012, 21:02:16 »
ok reading about the guy who took his pump apart n cant get it to run reminded me somewhere i had a link to the pump removal and replacement after exhaustive searching on my computer i found it!!
MODS if this is helpful pleae move it to the maintenance section as i can t seem to post it there?
http://bmw.dulaine.com/tips/replacing_injection_pump(M51).pdf
Re: 2.5TD injection pump removal and replacement
« Reply #1 on: 03 December 2012, 21:10:24 »
Have you ever found any benefit from fractionaly advancing the pump timing on these engines?
Omegatoy
  • UK
« Reply #2 on: 04 December 2012, 07:55:05 »
strangely enough,twice!!both times to help with the hot start problem some engines seem to souffer from,also appears to make the engine a little livlier,
however the best way is to set it with a dti gauge,to take account of chain wear,this usually cures the hot start problem completely but its a fair amount of work to do it
