This too good to believe?
Started by Vamps, 05 December 2012, 00:11:13
Whilst searching for James car, I found this, is this too good to be true, or should I be buying it?...... :D :D :D
Quote from: Vamps on 05 December 2012, 00:11:13
C'mon Mike! We're good here .............. but not mind readers!
We need a link!  :y :y :y
Quote from: Andy B on 05 December 2012, 00:13:02
Ive lost it.... :-[ :-[ :-[ :-[ :-[ :-[ :-[
Quote from: Vamps on 05 December 2012, 00:14:39
We've known that for a while ........ but what about the link?  ::) ::) ;)
Quote from: Andy B on 05 December 2012, 00:18:10
Found it....... :P :P :P
http://www.ebay.co.uk/itm/OMEGA-ELITE-ESTATE-AUTO-3-0-V6-1996-P-Reg-105K-MoT-Oct-13-Tax-31Jan-FSH-TOWBAR-/251194372380?pt=Automobiles_UK&hash=item3a7c59f11c
Quote from: Vamps on 05 December 2012, 00:19:46
Very nice looking car - interior is too pale for me - but isn't it a bit too pricey?  :-\ :-\
Had every faith in you finding the link  ;) ;)
bigboykarl
needs a cambelt as well ..last done in 2007.. :o
Quote from: bigboykarl on 05 December 2012, 00:46:22
because the seller believes (or wants the buyer to believe  ::)) that cambelt intervals are 8yr/80k miles  ;)
If the letter from Vx is genuine, then that is down to Vx if the belt snaps before 2015 :-\
Suspect money pit though, as it seems to have had alot of recent work... needs four new tyres if you're feeling fussy :-\ tried and tested budget tyres are one thing, but a brand you've never heard of...phrases like 'front wheel alignment juyst done, and now spot on' screams wishbones, especially  with new front tyres.
That erm air filter thingy dont look right and the water bottle looks very dirty  ::)
GastronomicKleptomaniac
Quote:
There is just one slight oil leak which is from the oil pressure switch located just above the sump
as it is so minor I've not changed it - a very easy and accessible component to change.
You can see this on the photo along with the waxoyl which has been sprayed there as well.
Nah mate, that's not waxoil, that's oil that's been pissing out of the oil pressure switch because the pressure release valve is stuck solid.... which is probably also why the camcovers have been 'resealed'.
Quote:
New set of HID Headlights fitted - and what a difference!!
No, Cheap Chineese hid ballasts and bulbs fitted in original 'glass' non-projector model headlights, with no washers or self levelling.
