Windscreen smearing issues...
Started by OmegaAnglesey, 05 December 2012, 17:08:02
This newspaper thing. Newspaper has ink on it. Printers ink is oil based.
OmegaAnglesey
Quote from: chrisgixer on 08 December 2012, 10:47:25
Yeah that's what I thought too.
After taking mine through a carwash, I had same issue (smears with every wipe).
I used white vinegar and scrunched up newspaper.
Zippy2012
i use TFR Traffic Film Remover all over my car, its faded anyway & has no shine so doesnt bother me,
it removes all polish,wax,oils,fuel,bugs,tar,silicons,grease,salt... etc etc whatever can be thrown up off other road users,
if you have nice shiny paintwork it will remove all of your polish etc so you will defo need to re wax the body work after its dried!
its a harsh way of removing all dirt put it in a trigger bottle & leave car dry! spray all over car windscreens bodywork alloys everything but DONT LET IT DRY add more & use a worn out scotch pad (sponge 1side corse on other ask your wife she prob washes up with them!) to clean windscreen/windows the wiper blades & alloys only!! use a jetwash & wash off all of car then rewash with your normal basics carwash with HOT water sponge like normal. That should do the job
next day polish bodywork! if required...
if not hammer & nail in the O/S section of screen in drivers vision ,just lightly tap it & it will chip&break then give it a smack or 3 with your palm to send a spider crack across screen or the screen replacement company may just repair chip & ull be back to square 1!!
GastronomicKleptomaniac
How long have you had the car? If the previous owner has applied any glass sealants (like Rain-X, but semipermanent), particularly if they've not done it very well, this could cause the same symptoms.
Get to Halfords, get some Intensive Glass Cutter, and a good microfibre cloth for buffing it off with. You're looking at £6ish for the bottle, it's brilliant stuff. Same section as the Rain-X etc.
You're a tad far from me else I'd do it for you :y
OmegaAnglesey
#35
Still have this issue and if anything it seems to be getting worse, As TB said "White Vinegar" maybe the brown vinegar was a bad idea :(
OmegaAnglesey
Quote from: GastronomicKleptomaniac on 08 December 2012, 19:55:28
Had approximately 3 1/2 years , Will try your suggestion too can't be any worse than using Vinegar :)
Omegaman, its important to change surface wettability..
use some polisher (although not easy) and then use rain repellents.. or use rain repellents alone.. it helped me..
ps: I guess your windcsreen changed with a non-original one and its not polished enough !
Put some methylated spirits in your washer reserviour, then put some chips in the newspaper, add vinegar (to chips) & jobs a good 'un ;D   :y
OmegaAnglesey
Quote from: PhilRich on 18 January 2013, 18:01:08
Before long someone will say rub fish and sausages on the screen with the "Vinegar and Chips"  :D ;D ;D
Quote from: OmegaMan2.2 on 18 January 2013, 20:20:48
;D ;D ;D  this made my day ;D :y
78bex
Could it be a quality issue with the screen?
As in the smears occur only because these are low points or something similar.
OmegaAnglesey
Quote from: 78bex on 18 January 2013, 22:26:00
Screen was fine last summer.
OmegaAnglesey
Not had much time to try white vinegar just yet, Would this stuff work ? Thought it would be easier to use in "Spray" Form.  :-\
http://www.amazon.co.uk/Decco-500ml-White-Vinegar/dp/B000TAN7PG/ref=sr_1_1?ie=UTF8&qid=1359228390&sr=8-1
