Radio wont switch off
Started by BlueBridge, 05 December 2012, 21:26:00
Quote from: BlueBridge on 05 December 2012, 22:23:14
Will give it a go, although Its never switched off with the ignition since I've had it. Just another problem to add to the long list of faults since I got her 3 months ago :-[ I wish I still had my old one :'(
Sounds like someone has bypassed the ignition switch, perhaps to use the radio without the key....... :-\ :-\  Although iirc the Omega radio will work for an hour without the key, well in the pre facelift it would..... :y
henryd
Quote from: Vamps on 05 December 2012, 22:27:01
My facelift ccr2006 did as well as does my Signum :y
other rides
Sounds like my car when i first had it although things do get better after a spout of head banging  ::) :-[
... although Its never switched off with the ignition since I've had it.
You can toggle this on my radio ..... it's in the manual somewhere  :y
Quote from: BlueBridge on 05 December 2012, 22:23:14I wish I still had my old one :'(
I've always said that ............  ::) ::)
My 2006 does this occasionally. Probably just a firmware bug in the radio. I'd ignore it unless it starts doing it regularly.
Quote from: Kevin Wood on 05 December 2012, 23:40:43
Difficult to ignore though if it is going full belt overnight..... ::) ::) ::)
Quote from: Vamps on 06 December 2012, 00:13:34
Obviously pull the fuse when it plays up, or you'll have a flat battery too. ;)
BlueBridge
Put the fuses back in this morning and all fine again, didn't even ask for the code, although computer had reset itself and it was New Years day 1999.... if only ;)
Still doesn't come on with ignition though :'(
Thanks again for all the help :y
Jon
