Radio wont switch off
Started by BlueBridge, 05 December 2012, 21:26:00
BlueBridge
Any one know why my radio wont switch off, and if I disconnect the battery will the power sounder go off?
Need a quick answer as the radio is on loud and I'm probably annoying the neighbours. Just nipping outside to have another go, and will check back in 5 mins,
Cheers boys :y
Jon
Quote from: BlueBridge on 05 December 2012, 21:26:00
What flavour is it?  ::)
Quote from: BlueBridge on 05 December 2012, 21:26:00and if I disconnect the battery will the power sounder go off?
Not if you disconnect it within 15 secs of switching the ignition off.  :y :y
It's in the manual  ::)
Quote from: BlueBridge on 05 December 2012, 21:26:00Need a quick answer as the radio is on loud and I'm probably annoying the neighbours. Just nipping outside to have another go, and will check back in 5 mins,
Cheers boys :y
Won't it turn down using either the radio's volume or the steering wheel controls?
BlueBridge
Or should I just pull the fuse?
Jon
BlueBridge
Quote from: Andy B on 05 December 2012, 21:30:06
Cheers boys :y
Its the NCDC 2013 nothings working volume or anything. :'(
Jon
Quote from: BlueBridge on 05 December 2012, 21:31:17
Cheers boys :y
Fuse sounds to be a good idea  :y :y
BlueBridge
Cheers Andy :y, now to look on here to see which one.
Jon
BlueBridge
Thanks again :y I love this site  :-*
Jon
BlueBridge
Andy #6 is just the speakers, any idea what # the radio is?
Jon
BlueBridge
Quote from: RobG on 05 December 2012, 21:34:48
Quote from: BlueBridge on 05 December 2012, 21:33:18
#6
Oops, sorry Rob just noticed you posted that, #6 is just the speakers, well the illumination is still on on the radio, any idea what number the radio is?
Jon
12
Courtesy light, boot lamp, hazards, information display, radio
BlueBridge
Thanks Rob, will try now  :y
Jon
BlueBridge
Sorted, any idea what the problem maybe????
Jon
Quote from: BlueBridge on 05 December 2012, 21:58:40
As the radio "should" switch off when the key is removed .. possibly that stupid little plunger thing at the bottom of the key slot is stuck ??
Try sticking the key in and out a dozen or so times?? maybe a little switch cleaner down the keyhole as well ??
Mind you .. I could be totally wrong ....
BlueBridge
Will give it a go, although Its never switched off with the ignition since I've had it. Just another problem to add to the long list of faults since I got her 3 months ago :-[ I wish I still had my old one :'(
Jon
