WANTED- N/S/F central locking motor & heated rear window relay.
Started by unlucky alf, 09 December 2012, 17:03:58
unlucky alf
I definately need the locking motor as it totally died today, & as my heated rear window has no power getting to the glass im guessing it could be the relay (fuse is fine), Far easier to plug one in to try rather than dismantle the whole flippin' tailgate in this cold weather :y,,,,TA!.
Pretty sure I will have a relay (although I will need details of which one it is),not sure if I have a c/l motor.Will have to check. :y
unlucky alf
Quote from: Albitz on 09 December 2012, 19:50:54
The relay is mounted in the fusebox under the steering column, If I recall its sort of top left, I'll have a look tomorrow & get the number off of it,,,cheers :y.
unlucky alf
No longer need the relay as I found it was a dicky wire, But I still need the central locking motor if somebody could fall over one somewhere please. :y
The Red Baron
unlucky alf
Quote from: The Red Baron on 16 December 2012, 17:58:20
i will dig you one out Tim.  :)
Many thanks,,,,,You are a hero despite of what all the others say ;D,  :y
The Red Baron
Quote from: unlucky alf on 16 December 2012, 19:23:51
yeh, dont listen to em tim.  :)
