Pages: [1] 2 3  All   Go Down
Author Topic: help please  (Read 9791 times)
omega1oon
  • cannock
    • satin red 3.0v6 saloon
help please
« on: 10 December 2012, 23:03:39 »
hi every 1 not been on for a while as been busy but i need your help please :)
now I have a 3.0 v6 omega that has a problem that is driving me nuts now
so from start up from cold it is fine, revs up ok and is like a roket but after abut 20 min it starts to feel abit down on power and when at a constant speed it feels like it is surging like asthou 1 bank is lower on power to the other and it also will NOT rev past 3500 rpm(bounces like it hits the limiter but slower) and no EML light or any other warning light comes on at all. i however have had a new coil pack,HT leads,plugs,fuel filter,oil and filter change and a blanked egr valve
so if any 1 has any idear what it could be please let me know as it will be much appreciated
always looking for spairs :-)
Re: help please
« Reply #1 on: 10 December 2012, 23:08:23 »
I'm off this week. You're welcome to pop down to me (at less than 3500rpm  :P ) and we'll give it a once over :) :y
omega1oon
  • cannock
Re: help please
« Reply #2 on: 11 December 2012, 19:23:18 »
thanks for the offer mate but not got the time or the cash at the mo as its so close to x-mas and it would take me more than 2 hrs to get to you lol  :-)
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
Re: help please
« Reply #3 on: 11 December 2012, 21:14:18 »
...and no EML light or any other warning light comes on at all.
Does it come on with the ignition lights when you first start the car?
2woody
  • Northumberland
Re: help please
« Reply #4 on: 11 December 2012, 21:45:08 »
have you got the lambda sensors back-to-front ?
omega1oon
  • cannock
Re: help please
« Reply #5 on: 11 December 2012, 22:25:40 »
EML light works as it should and the lamda sensors have been in same position for the last 4 years
omega1oon
  • cannock
Re: help please
« Reply #6 on: 21 December 2012, 13:39:17 »
managed to have a look at it and changed the IAV and the MAF no change so while it was running i unpluged the cam sensor and EML came on (flikering) but still was the same then unpluged the crank sensor still the same but no EML light.
so im going to get the cam and crank sensors as there what most have advised me that it could be just hope i get it sorted soon as not got much cash to throw at it.
has any 1 else had this sort of problem ?
Re: help please
« Reply #7 on: 21 December 2012, 16:28:59 »
Changing cam and crank sensors without proper diagnostics is likely to be just a waste of your hard earned mate - have you paperclipped it?  Any codes?
omega1oon
  • cannock
Re: help please
« Reply #8 on: 21 December 2012, 18:35:07 »
as ive sead it has no errors and i now it is not a mechanical as it is sweet to drive but just not rev over 3500 rpm  ???
Re: help please
« Reply #9 on: 21 December 2012, 20:25:06 »
Its in limp mode which means the ecu is seeing a fault - you need codes reading - post codes up here to help diagnostics.
If its "sweet to drive" unlikely to be dodgy cam or crank sensor ;)
omega1oon
  • cannock
Re: help please
« Reply #10 on: 22 December 2012, 08:03:44 »
Ok mate thanks and ill guess I will have to get a reader for it or do the paper clip test if some 1could show me with a pic and how to as not done it before to be honest
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: help please
« Reply #11 on: 22 December 2012, 08:13:01 »
not being able to rev above 3500 sounds like a fueling problem, imp mode wont allow above rev above 1500.
 change fuel filter also you could have some dodgee fuel not unknown these days,
Hoof'land storeman.
omega1oon
  • cannock
Re: help please
« Reply #12 on: 22 December 2012, 08:46:09 »
Been throu 3 tanks of fuel at different stations already and have a new filter since . I have though it could be my fuel pump on its way out or the pressure reg not working correctly ?
biggriffin
Re: help please
« Reply #13 on: 22 December 2012, 09:22:45 »
Urm.
 make sure all vacum pipes are fitted correctly on the pressure regulator,and.not leaking.
 if you have a regulator then try it,dosnt sound like a sensor as no eml light,
Hoof'land storeman.
omega1oon
  • cannock
Re: help please
« Reply #14 on: 22 December 2012, 10:22:38 »
Urm.
not got a spair reg but i was going to up rait it any way .
but the TC light came on yesterday wouldnt go out even if i pushed the tc button car hadnt moved as i was working on it but it went off when i switched the engine off then back on again
Pages: [1] 2 3  All   Go Up
