PAS fluid change... Alone
Started by JamesV6CDX, 12 December 2012, 12:15:59
Hi Guys
I'm a billy no mates, at the moment  :P and need to change the PAS fluid on my Jag (and add in an additive from Jaguar - Tech Bullitin to cure squeaky steering!)
It looks like it'll be easy enough to do this in the usual way, EG, disconnect the return, put it in a jug, and run the engine whilst going from lock to lock, to get the oil fluid out, whilst topping up the reservior...
But... this is kinda a two man job. Other than arm extensions... any ideas for how this job could be done alone! ;D
Thought not..... I'll have to get SWMBO to assist when she's not at work :D
Will read this with interest, PAS fluid on 2.2 needs doing as well. Where did you get new fluid from?
Quote from: tunnie on 12 December 2012, 12:25:40
It's a peice of cake with 2 people... :y
It uses ATF... The Omega must be dex 2, not dex 3... :y
MaxV6
i have some time early next week potentially james , be happy to help if it coincides with your rest days....
jag ought to fit in the garage here , so you can be heated as well....  if you like,   or i could wander over to you.
I plan to be back in Brackley this Saturday, 2.2 needs some TLC  :)
