ATF change on the Jaag!
Started by JamesV6CDX, 12 December 2012, 13:11:54
Hi Guys,
I want to change my ATF on the Jag.
I thought I got lucky when I saw the drain plug on the sump ;D But I can't find a filler anywhere  ::)
Anyone know about these things? I must say, the Jag forum's are not a patch on this one :y
Quote from: JamesV6CDX on 12 December 2012, 13:11:54.....
Anyone know about these things?  .....
I take it then, the Jag also lacks a dip stick  :-\
Quote from: Andy B on 12 December 2012, 13:13:36
Yep!
Jag forum's say it's "sealed for life"
More like.. "sealed until life is over (due to lack of ATF servicing!)"
I was kinda hoping I could drain, and refill via dipstick tube... no such luck!
Gaffers
Mine has a dipstick which comes out in to the engine bay by the rocker cover.
gottit
"At the 2 o clock point on the rear of the transmission, there is an inspection/filler point for use by Jaguar Service Technicians only"
That'll be the badger, then!!
Quote from: Guffer on 12 December 2012, 14:01:59
I'm liking the sound of those old Jags even more  ;D
Gaffers
Quote from: tunnie on 12 December 2012, 14:32:55
That's why I got an AJ16 as old as I could find.  Once Ford got their hands on the XJ they f***ed it up
Quote from: Guffer on 12 December 2012, 14:37:44
Ford ones are V8 I guess?  :(
Mine is a 2001 3.0 V6, and that's a ford in disguise ;D
The block itself is ford, though many of the ancils etc are Jag specific.
Thankfully rear wheel drive, though :y
The Ford Jags are money pits.
If you are unlucky enough to have one with a Ford Autobox, sell it before the "Gearbox Fault" comes up on instrument panel. Be quick!
serek
Quote from: TheBoy on 12 December 2012, 18:10:10
agree
lucky if you ger 100K with out problems
I hade few of S type with gearbox issue , 2 of those where need replace solenoid
serek
Hi Guys,
have look on dirve side near exhausts there 8mm torx bolt
for level check oil temp need to be 35-40 C
2woody
#12
sorry guys, but X300 was the first Ford Jaguar
Is yours a six-cylinder XJR Guffer ? in that case, it will have a GM autobox. (4L80E - the big brother to the Omega's 4L30E )
BazaJT
Any XJ  from[I think]1997 onwards,that is with a V engine as opposed to the straight six has a "sealed for life"gearbox.The ATF change can be done but is more of a specialist job as the new fluid has to be put in under certain temperature conditions as well as anything else.I believe this costs quite a lot even at a Jaguar Independant place.Jaguar warranties[if applicable]will be voided by having the ATF changed,but the JEC recommend that is done.This is one of the reasons I opted for my old faithful straight six X300.
2woody
the X308 ( ie the V8 ) XJR had a Mercedes gearbox......
