Author Topic: Locked Out!  (Read 1859 times)
martynbrowne
  • West Norfolk
    • Omega 2.5 cd estate
Locked Out!
« on: 13 December 2012, 18:25:58 »
My 2.5 cd locked me out while I went behind a bush with the keys still in ignition. I had to get my son to leave work, get my spare keys and bring them to me. Happened again when I fuelled up but this time I was prepared!. Any ideas why?
Re: Locked Out!
« Reply #1 on: 13 December 2012, 18:39:03 »
Don't know but there has been a couple of occasions over the last few months when mine has dead locked even though the engine is running ???
twiglet
  • Norwich, Norfolk
Re: Locked Out!
« Reply #2 on: 13 December 2012, 20:03:19 »
That's not good!  :o
Agemo
  • Cleethorpes
  • Insignia
Re: Locked Out!
« Reply #3 on: 13 December 2012, 21:25:50 »
Not good at all, especially in a collision!  Hope you have A spare key hidden now, and intend finding the fault.
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
Re: Locked Out!
« Reply #4 on: 13 December 2012, 22:01:29 »
That's not good!  :o
Not good but quite funny. :)
The neighbours Peugeot locks ALL the doors whenever the drivers door is opened or closed, twice we had to 'break into it' the other day whilst I was changing the glow plugs, I guess the wires are worn where they pass through into the door from the car body...
flyer 0712
Re: Locked Out!
« Reply #5 on: 13 December 2012, 22:46:16 »
Had the same while using cigarette plug in tyre inflator...engine running...wire through drivers door me outside..closed drivers door...deadlocked itself...my house keys were on the ignition key it was peeing down with rain.....freezing brass monkeys..no coat on..my mobile was in my car and i could not get into my house for my spare car key....had to knock a neighbours door ask to use his phone to contact my sister to bring spare front door key....an hour later she turned up with it.........got my spare car key opend the door it was so blinking hot in my car and i was so cold and wet that i sat in there for twenty minutes to thaw out.....so now carry spare car and house key in my jeans pocket...lesson learned.. :y
martin42
Re: Locked Out!
« Reply #6 on: 14 December 2012, 13:00:17 »
if im working on the car i always make sure a window is open,just incase ;)
Re: Locked Out!
« Reply #7 on: 14 December 2012, 13:10:49 »
Well, these might help for a start. ;)
http://www.bgashop.co.uk/index.php?_a=viewProd&productId=128
I reckon it might be worth checking the switches behind the lock barrel on the driver's door. If they are making contact when shocked by the door closing that might explain the problem. It could also be the microswitches in the central locking motor. Might also be worth a look at the condition of the wiring between door and door post, and also checking the connector as the wiring passes into the door post for security. Could just be a poor connection here.
Welcome to the forum. :y
