Author Topic: Windscreen Wipers  (Read 2273 times)
blackviper90210
  • Bromsgrove, West Midlands
    • 03 3.2 Elite Saloon
Windscreen Wipers
« on: 14 December 2012, 00:42:51 »
Evening all,
My dad rang tonight ref his mig and was wondering if you can help please?
The wipers operate fine, but when he turns them off, they no longer park in the normal position but in the middle of the screen.
Turn them on again, they goto the bottom of the screen and continue to work as normal??
Any ideas what causes this please?
TIA  :y
AKA - Mr Bracket
adey2
  • nuneaton, warwickshire
  • if all else fails hit it with a hammer
    • 2000 3.0 elite estate lpg
Re: Windscreen Wipers
« Reply #1 on: 14 December 2012, 00:46:41 »
ive found its to do with the contacts in the motor, they get dirty or worn out so dont know where to park the wipers, new motor time unless you fancy stripping it down to clean contacts   hth
v6 locking kit , code reader available, engine hoist and engine stand
also has 2.6 mv6 estate 2001, hilux surf 3.0, vectra 2.0 lpg 2000
adey2
« Reply #2 on: 14 December 2012, 00:52:22 »
or the other prob i can think of is the perm live feeds fuse has blown or broken wire, thats how it manages to keep operating after switch turned off till it hits park position
« Reply #3 on: 14 December 2012, 05:30:01 »
Mechanism has slipped on the motor shaft, probably stuck to the screen in the recent cold weather.
It's just a case of undoing the nut on the motor shaft, repositioning the wipers, then do the nut back up. There are marks on the casting to guide positioning. |<  | or something like.
Might need the scuttle off, first time you do it.
blackviper90210
« Reply #4 on: 14 December 2012, 06:04:32 »
Thanks for the suggestions guys!!
I'll check that it hasn't slipped first as you suggested Chris, then work my way round fuses and finally the motor change.
He's due over next week, so I can check it for him then!!
Thanks again :y
AKA - Mr Bracket
« Reply #5 on: 14 December 2012, 06:30:55 »
Mechanism has slipped on the motor shaft, probably stuck to the screen in the recent cold weather. ......
That's the one ....... as you say, not checked the wipers weren't frozen to the screen before they were switched on  :)
« Reply #6 on: 14 December 2012, 16:41:33 »
+1  :y :y
« Reply #7 on: 14 December 2012, 18:36:26 »
Mine recently slipped as I'd left the wipers on auto and they were frozen when I started the engine :-[ :-[
Fortunately it was fixable by moving the wipers themselves as they were still parking at the bottom, just going too far and the N/S was hitting the wing ::)
« Reply #8 on: 14 December 2012, 21:26:14 »
yes thats nearly cought me out a couple of times. rain the night before on the way home, followed by freezing conditions the next morning. Luckily, the wiperrs broke free before they slipped and lost the park position.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #9 on: 14 December 2012, 22:58:40 »
 ive just had to put a new set of wipers on as like a silly :-X.
  i got in the shed tother morning all nice n icee turned on the wipers and bang there goes the blades, nice nicks in them couple small black rubbers left stuck to the screen. note to self de-ice window before turning wipers on.
Hoof'land storeman.
