Author Topic: Track rod & cam change kit  (Read 1868 times)
cruisemachine
  • north/central london
    • O2 plate 2.6 v6
« on: 15 December 2012, 13:04:58 »
Hi folks just after a bit of advice following the horrible clunking sounds and wayward steering Im pretty sure I need to change my driver side tracking rods and I'm due a cambelt change around now so I figured I'll do that aswell .
I'm just after advice on the best place to get these parts as obviously I don't want to put crap on but in these hard times I don't want to pay through the nose .
It's an O2 plate 2.6 v6 not sure on the chassis number .
Any prods in the right direction would be greatly appreciated thanks and if I can put some business towards a fellow forum member that would be ideal .
Cheers folks  ;D
v6man54deg              Geffd
  • Wirral Merseyside
  • V6 man
Re: Track rod & cam change kit
« Reply #1 on: 15 December 2012, 16:57:04 »
Where ever you get your belt kit from make sure that they will return it if there are any problems with it i.e noisy rollers or tensioner.
I did a belt for someone in August within two days the tensioner began to make a squeaking noise when hot on stripdown you could see a trail of grease leaking out of the tensioner bearing - I bought another set and fitted it to the customers car no problem - but was then out of pocket for the parts as the supplier wanted to return the kit to SKF. this procedure took three months! until i finally got a full refund.
As this engine finished production in 2004 I suspect SKF who are the sole supplier of the rollers probably produced enough for what they thought the life of the engine would be - there fore there are a lot of them lying around in warehouses with seals drying out that can cause problems when fitted to engines.
V6 problems solved : Worked at the V6 Engine plant for 13 years on durability testing and warranty issues, this job included many trips to Russelsheim, Trollhattan, Michigan, Atlanta,keiserslaughtern.
« Reply #2 on: 15 December 2012, 17:29:13 »
Cam belt kits - get a Contitech kit from Buypartsby (~£60)  - you will also need use of a proper cam locking kit to change the belt etc otherwise you won't be able to time it spot on.  There's a brilliant DVD in the Omega shop showing the whole procedure - well worth buying and watching.
Track rod - I've used pattern (eg QH) without issue
HTH :y
« Last Edit: 15 December 2012, 17:31:16 by dbug »
v6man54deg              Geffd
  • Wirral Merseyside
  • V6 man
« Reply #3 on: 15 December 2012, 17:30:41 »
by the way if yours is an 02 reg it will probably be the none excentric bottom roller
« Reply #4 on: 16 December 2012, 10:24:09 »
Good point, probably will be, much easier, once over the panic of confirming the correct kit. ;D
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #5 on: 16 December 2012, 16:26:47 »
Which, for the OP's benefit, means that the DVD, while very useful, does not cover his model. :y
cruisemachine
    • O2 plate 2.6 v6
« Reply #6 on: 16 December 2012, 16:30:25 »
Bugger I got the DVD a couple months ago in preparation oh well .
Cheers for the advice folks
« Reply #7 on: 16 December 2012, 17:54:26 »
its a minor difference, the dvd is still relevant for 90% of the rest of the procedure, but you,ll be ahead as the non adjustable bottom roller means less work, as cams 3 and 4 will be set, you only have to adjust cams 1 and 2 via the top eccentric roller.
seemples. :)
Shackeng
  • Ramsbury
« Reply #8 on: 16 December 2012, 18:21:09 »
seemples. :)
I wish I'd known that when I did my 3.2 earlier this year, I was scratching my head trying to make the DVD match mine! Still it runs OK, so it must have been close. :-[
v6man54deg              Geffd
  • Wirral Merseyside
  • V6 man
« Reply #9 on: 19 December 2012, 17:12:16 »
they are actually easier to do as there is no adjustment for the right hand bank - just have to put all the slack to the right hand bank put the roller on then move the slack back to the the tensioner - you can still fit the excentric bottom roller to this model
Shackeng
  • Ramsbury
« Reply #10 on: 19 December 2012, 18:53:49 »
At least I know for next time in 4 years.! However, as I'll be 80 then, I may ask a mobile to help. :y
