Author Topic: Help for a numpty!!  (Read 1607 times)
dazzle72
  • nottinghamshire
    • Omega 2.2 CDX Estate
Help for a numpty!!
« on: 16 December 2012, 21:13:59 »
I am no mechanic, but need some assistance please. Where is the coil pack located on a 2.2 petrol?? Also the engine light is on so want to try the pedal trick I've seen mentioned but cant find it!! Realise it may not work, but worth a go. Any help will be appreciated. Car runs fine by the way, just want to check obvious things like coil pack, etc and make sure scuttle isnt leaking water all over it
Re: Help for a numpty!!
« Reply #1 on: 16 December 2012, 21:15:53 »
I am no mechanic, but need some assistance please. Where is the coil pack located on a 2.2 petrol??  ........
clipped directly to the top of your park plugs.  :y :y
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
« Reply #2 on: 16 December 2012, 21:17:56 »
:-X
dazzle72
  • nottinghamshire
« Reply #3 on: 16 December 2012, 21:29:21 »
Yep, got it thanks guys. Also found the pedal trick, just tried it with no luck.
« Reply #4 on: 16 December 2012, 22:00:11 »
:-X
OK what's a S between friends  ;) ;)
