Author Topic: omega missing first gear but goes through the rest fine. plz can anyone help.  (Read 3735 times)
dazza88
  • luton (bedfordshire)
    • 2001 2.6 v6 auto omega
hello.
i think im in the right topic room, ,my 2002 2.2 16v cd on an auto box is missing first gear so it pulls away in 2nd gear even though it dont go in 1st gear it goes through all other gears lovely and my engine management light is on, some one told me it was my gearbox sensor unit but does anyone know if its my speed check sensor or my output sensor, can anyone help or has this happend to any one else or is this normal. many thanks darren
2002 2.2 cd auto             mrk2 astra gte
vauxhall colton               vauxhall omega 2.6 v6 auto
ford sierra saphire 20l   vauxhall omega 2.2 dti 02 plate
Murph
  • Dartford, Kent
    • 2.5 Estate
First thing we'll need is the fault codes that have been stored.
It may sound silly but have you made sure the "Snow mode" switch isn't on?
dazza88
hello, were would i find the code or did you mean the code number of what the machine gave me, thats a good question i havnt checked the snow button but would that trigger my management light on. thanks darren
  • Online Online
...... or did you mean the code number of what the machine gave me, .....
Yes  ;)
dazza88
Ok cool il pop back tomoz and wright it down thats what i should of done first time round lol.
Murph
  • Dartford, Kent
    • 2.5 Estate
Yep once you get that someone will be able to give you the right advice.
Snow mode puts it in 3rd gear mate ;)
dazza88
hello all, ive just brought the car back to mine and i tryed pushing the snow mode button and i pushed the sports button 2 and none of them 2 buttons light up and the s didnt come on dash bored, any ideas or is that all done to the sensor.
symes
  • oxford
    • R reg 940 volvo
think theres a fuse if so under steering column 2nd row down from top extreme left(9) hope that helps :y
4 pots are known for cam sensor upsetting the gear box. So check engine codes, as well as gear box codes. IMO.
Broomies Mate
  • Bristol, UK
    • Stuff!
Limp mode and Ice mode both put the gearbox in 3rd for start-off.  Sounds like your car is in Limp Mode.  The codes will reveal all!
You should be able to manually select 1st and 2nd gear should you require it.
dazza88
hi mate ive tryed doing it manually in 1st but it just revs like in n or park, so i manually put it in 2nd and it was fine
dazza88
hi mate ive checked the fuses and they were fine  :'(
Broomies Mate
  • Bristol, UK
    • Stuff!
With the recent rain/salt/ on the road, muight be worth giving the Transmission Selector Switch a clean!
dazza88
[/quote]
oh right yer thats true, were abouts is that plz is that the one one gearbox on the left
Page created in 0.012 seconds with 14 queries.
