Author Topic: Pin Thing  (Read 1226 times)
Pin Thing
« on: 19 December 2012, 17:18:00 »
Offside rear door pin that pops up when locking and unlocking keeps sticking up and wont go down until activated a couple of times with the remote ... Any ideas how to loosen it up without damaging the leather surround . Couple of time i got back to the car not realizing the door is not locked properly  :-\
Re: Pin Thing
« Reply #1 on: 19 December 2012, 17:27:29 »
probably something wrong with the lock motor..  I changed the drivers side some time ago..
Re: Pin Thing
« Reply #2 on: 19 December 2012, 17:30:07 »
As cem says .. not just the pin .... that is simply a long piece of wire connected to the actuator/motor.....
The pin movement is a function of actuator movement, so you need to take the doorcard off and see what is preventing full movement .. it might just need lubrication of the mechanism at best .. at worst it might need replacement ...
Re: Pin Thing
« Reply #3 on: 19 December 2012, 17:31:49 »
Hope not  :-X
Does the pin thing pull off so i can squirt something down it  ???
Re: Pin Thing
« Reply #4 on: 19 December 2012, 17:36:24 »
Hope not  :-X
IMHO that would achieve the square root of zero.
"squirting something down" a piece of wire just ends up with the "something" dripping off the other end .. the chances of it getting to where it is actually needed are remote, to say the least.
Job needs doing properly, door card off to diagnose, then rectify as appropriate.
Re: Pin Thing
« Reply #5 on: 19 December 2012, 17:42:01 »
Hope not  :-X
 :) will do ... hopefully i can do this job if not too fidly  :-\
Re: Pin Thing
« Reply #6 on: 19 December 2012, 17:55:55 »
This is the guide EMD for removing the rear door card on a pre-facelift:
http://www.omegaowners.com/forum/index.php?topic=90556.0
Hope that helps :y :y
Re: Pin Thing
« Reply #7 on: 19 December 2012, 17:59:21 »
Hope not  :-X
Have a read here in addition to Lizzies post .. gives some more info that "might" be useful ..
http://www.omegaowners.com/forum/index.php?topic=90543.0
Re: Pin Thing
« Reply #8 on: 19 December 2012, 17:59:55 »
Cars this old you need to expect to have to do at least one door with a central looking issues at some point IME.
If the button moves, the motors is working, but usually the locking mechanism is stiff and causing resistance to the motor which it can't over come. So it fails to lock.
At least that's me experience anyway.
Re: Pin Thing
« Reply #9 on: 19 December 2012, 18:05:20 »
Thanks everyone  :) Looks like the rain will stop play if it keeps hoofing it down like it is just now . Had a look at the guide and looks fairly easy ...what could possibly go wrong  ;D
Re: Pin Thing
« Reply #10 on: 19 December 2012, 18:35:11 »
now you may escape with some wd40 or other juice but sooner or later you will change this lock motor ;D
and the next step is fuel tank lock motor ;D ;D
and then ........... :-X
« Last Edit: 19 December 2012, 18:37:31 by cem »
