Glad i lease this Trafic
Started by Taxi_Driver, 23 December 2012, 20:50:16
Taxi_Driver
It went in for a service at 100k (not 2 yrs old yet)
Since then i have done in a couple of weeks another 3k.....but the gearbox has been whining in 5th and 6th gear at about 50+ mph since the service
So i took it back in, mentioned the whining gearbox.....thinking they might want to check the oil level of it or even change the oil.....
Got told.....nothing you can do with the gearbox, until it goes wrong  ???
Still, its not mine.....
Crazycarzowner
I always thought prevention was better than cure & less expensive  ???
symes
Jukeboxnut
Sometimes I wonder about the competence of so called mechanics these days.
martin42
had clutch changed the other week on my vivaro,09 plate,now on 109k ,clutch pedal went to floor and stayed there,csv went,today driving back home did it again,after 4 weeks of having new clutch replaced,i wonder if these mechanics would be this crap if it was there own car,also the gearboxes are crap on the traffic  :(
Plagued with box issues those vans, I had a 54 plate that used to chatter at 70k miles, then a 57 plate more recently, that was whining at 64k miles. A friend has one who had 3 gearboxes in one.
Taxi_Driver
Quote from: martin42 on 24 December 2012, 12:22:53
That happened on mine at 80k......garage changed the clutch and slave cylinder
French shite. Never buy French. Amazing following from French people though, no French members here that I've seen.
sassanach
this is what happens when you use a car gearbox in a van
If it's any consolation, it took Seat two goes to diagnose a faulty slave cylinder >:(
That and leaving bits of the pedal assembly in the footwell along with not refitting the cap to the fluid reservoir cots them a free cambelt change ::)
Its difficult to comprehend how a clutch pedal hitting the floor can be diagnosed as the clutch itself
hotel21
Quote from: Marks DTM Calib on 25 December 2012, 15:48:12
It can if its a tdi disco. The pivot pin pings through the actuating fork and the pedal is on the floor as a result.
