Author Topic: Av subwoofer question  (Read 2013 times)
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« on: 23 December 2012, 20:55:50 »
My active sub takes is signal from the av amp via a 75 ohm coax cable.
What role does the coax screen have ?
Is it just a case of a screen down to earth for filtering out any interference or has it any other use ?
2 years back, I run a cable behind the coveing and down under the plaster so I could relocate the sub to a better position.
Needless to say, i've just got round to trying it out and the bugger does not work  :'(
It may be the av amp settings. It was sat in a wardrobe for 9 months with no power so it would have lost all its settings  ::)
Just to round it off, I can't find the instruction book  >:(
The amp is a Yamaha dsp  :y
Not looked into the fault yet, thought it was best to sit down with a beer and chill before I get the multimeter out   :-X
I_want_an_Omega
Re: Av subwoofer question
« Reply #1 on: 23 December 2012, 20:58:23 »
Dead easy to check the cable Steve - but you know that  :y
Yam amps can be set to "none" as far as the sub output is concerned - should be that IMHO.
Good luck - Rob
Martian
« Reply #2 on: 23 December 2012, 21:10:57 »
It's the ground return.
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #3 on: 24 December 2012, 10:59:32 »
Oh bugger
Amp set up for 6.1 with sub active
No output from the amp.
Cable bells out ok
Tried it with another lead with no luck
Has the sub output on the amp got its own internal fuse ?
I_want_an_Omega
« Reply #4 on: 24 December 2012, 11:05:56 »
Oh bugger
Cable bells out ok
No.
But if you increase the volume level on the sub to max then try just touching the input cable centre conductor with your finger & you should hear "hum" from the sub. Do that locally and you should hear it if the sub is ok, if so then do so again with the long cable to prove that. No hum probably means a dead sub. Does the sub have speaker level inputs? If so then there is a plan B. Also a plan C but lets take it one step at a time.
TTFN - Rob
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #5 on: 24 December 2012, 11:21:33 »
Oh bugger
Cable bells out ok
No.
TTFN - Rob
Ok, just turned the volume up to max on the sub and had a play with the cable.
With just the centre part of the plug touching the socket, it hums like a good un.
As soon as the plug is pushed all the way home then the sound disapears.
The sub is a cheapo Eltax with the direct speaker inputs.
I_want_an_Omega
« Reply #6 on: 24 December 2012, 11:29:34 »
Oh bugger
Cable bells out ok
No.
TTFN - Rob
That proves the sub is ok then Steve. So, it has speaker level inputs x 2 AND a single phono socket? Do you have to switch between them somehow?
If not then you have (IMHO) proved that there is no output from the amp - which is odd as Yams are pretty solid IME. Try switching the sub O/P off & on a few times to see if that helps.
If it fails than you could connect ONE of the speaker level outputs via the cable to one of the  speaker input on the sub. That will only give you L or R bass - but will be better than nothing and at zero cost. The speaker inputs on the sub are high impedance so there wont be any mismatch issues either.
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #7 on: 24 December 2012, 11:41:15 »
No Switching between inputs, just a on / off switch and a volume knob.
I'll give the rest a try later :y
Just been told by the missus since she has got christmas eve off for the first time in years,  I have to go into town for a beer with her  ::) :y
It would be rude to say no  ;D ;D ;D
Thanks for your help mate. :y
Merry christmas  :)
I_want_an_Omega
« Reply #8 on: 24 December 2012, 11:44:14 »
You are very welcome mate  :y
My plan C was a spare sub that I have - but seems that isn't the problem ..........
Have a great xmas and lets hope for a decent 2013 .............
ATB - Rob
Martian
« Reply #9 on: 24 December 2012, 16:54:35 »
To prove the sub output on the amp is working (which I suspect it is as the sub needs a speaker level input as opposed to line level), connect a pair of walkman type headphones to the sub output and you should hear the bassline frequencies to whatever is being played.
I_want_an_Omega
« Reply #10 on: 24 December 2012, 17:29:16 »
Got me thinking there - he hasn't actually confirmed whether he has a line level input yet has he? Lets wait and see ............  ::)
« Reply #11 on: 24 December 2012, 19:23:28 »
In some ways he has as he states that its a coaxial input. Key question is, what sort of cable has been used and are the 0V`s connected correctly?
Also, did you use a good quality screened cable for your install?
Martian
« Reply #12 on: 24 December 2012, 20:04:02 »
My money says it's an RCA connector that is expecting to see speaker level voltages, although I would expect to see the ability to change that to line level input even on the cheapies.
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #13 on: 25 December 2012, 12:19:28 »
Ok, my cockup for not storeing the amp better  ::) :-[
The socket on the amp was loose causeing it to sort out behind the socket.
Just popped the cover off and attacked it with the soldering iron this morning with great results.
Thanks for your help lads  :y
Oh yeh, the extention cable was run in RG59 screened cctv cable in a seperate conduit away from any mains cables.
Tbh, it sounds a hell of alot better then before.
Or maybe i've just washed my ears out  ;D ;D
STMO123
« Reply #14 on: 25 December 2012, 12:21:08 »
Your neighbours will be thrilled, I'm sure. ;D
