car misted inside in the morning..
Started by cem_devecioglu, 25 December 2012, 16:33:54
today weather was fairly better so decided to use  the miggy.. but when I get inside all windows front , rear and side glasses were all  frozen( mist) inside as last days were a bit snowy+rainy..  checked the pollen filter , it was dry.. water drainage channels under scuttle  in both sides clean.. carpets dry..  ???
fiddled with the internal circulation valve , after several trials button start to work (probably dusted inside) and the valve start to work but I noticed it sometimes become half open.. ???  asked for the part (internal circulation valve) its now excluded from import parts list (all dealers)..
besides today when in job, I have noticed some cars misted inside (at least 20-30%) some not..
any ideas welcome :y
Varche
You could get the part from a breakers off the forum (payment by Paypal?)
I do no know the valve you are talking about but is it operated by vacuum? Maybe the pipe has an intermittent leak?
Quote from: Varche on 25 December 2012, 17:50:45
yep.. its operated by vacuum..but looking at the amount of condensation there must be a leak but everything is dry  ???
tonight I covered the car ..will see tomorrow if there will be mist or not..may be leaking from doors..
I know I can get the part but first I must be sure of the problem.. thanks Varche :y
Glovebox out, two solenoids by the side of blower fan, black rubber pipe = hbv,  black/blue rubber pipe = recirc flap. As solenoids are identical you can swap them over for elimination purposes
Quote from: RobG on 25 December 2012, 20:09:53
thanks for precious info Rob.. Will try as soon as I'm available :y
Quote from: cem on 25 December 2012, 20:37:45
Also worth checking the basic vacuum supply is OK. If you've got access to a vacuum gauge check the supply to the solenoids is sucking down to 30-40kPa or so and that the vacuum stays for a minute after stopping then engine. Most likely to be the flap fouling on something, IMHO. Could try securing it in the "non recirc" position?
Quote from: Kevin Wood on 26 December 2012, 10:54:59
another detailed information.. thanks Kevin.. :y
as I see flap fouling from time to time.. but I think it becomes stuck.. I will try all the info/methods given here..
but I think it requires digging the setup from the car and examining closely..
