Author Topic: What size is the top hose?  (Read 1401 times)
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
« on: 28 December 2012, 15:14:14 »
I'm on a mission to replace those flipping spring hose clips with good honest jubilee clips - what size do I need to connect the top hose to the coolant transfer pipe? Ta in advance :y
cnj
  • ludgershall
    • 2.2 Manual CD(51 plate)
Re: What size is the top hose?
« Reply #1 on: 28 December 2012, 15:16:19 »
from memory, about 3 inch i think !
« Reply #2 on: 28 December 2012, 15:39:52 »
Just stick with what GM fitted, they're better suited to plastic stub pipes  :y
andyc
  • Norfolk
« Reply #3 on: 28 December 2012, 15:49:19 »
Transfer pipe end is 44mm and the rad end is 49mm
GM do a jubilee which is 32-50mm Pt/No 91145654
Ok heres the rest of the sizes
12-20mm, 91145650 £0.57
16-27mm, 91145651 £0.51
20-32mm, 91145652 £0.65
25-40mm, 91145653 £0.60
32-50mm, 91145654 £0.80
40-60mm, 91145655 £0.95
50-70mm, 91145656 £1.02
These hose clips are made by Norma not Jubilee but they are the same thing
Cheers
Andy
Thetford. Norfolk
« Reply #4 on: 28 December 2012, 16:14:26 »
Absolutely. :y
andyc
  • Norfolk
« Reply #5 on: 28 December 2012, 16:19:10 »
Horrible sodding things, got the cuts on my hands as well. Always bin them and fit the screw type listed above.
Nice think with these is the screw head is 1/4" so you can you a flexi bit driver on them
Andy
Thetford. Norfolk
« Reply #6 on: 28 December 2012, 16:41:14 »
Andy
A Jubilee has a hex head too 6mm or 7mm  ;)  ;)
« Reply #7 on: 29 December 2012, 14:55:03 »
Andy
Once again, you're a superstar :y
Ta all!
