Author Topic: MV6 ignition  (Read 3750 times)
cwill144
  • Oxford
    • 1998 MV6
MV6 ignition
« on: 29 December 2012, 12:46:03 »
I have just went to use my car and the ignition has gone, the key turns but engine will not turn over when I remove the key the dash lights are still all on and the key spins freely no notch between positions. obviously I will need a new ignition barrel.
The car is a 98 3.0L MV6 if I get a new barrel and key off Ebay is the transponder in the lower part of the key? which will mean have to get new keys programmed, or do I need new barrel, key, transponder and ECU? any advice of the easiest fix will be appreciated.
Re: MV6 ignition
« Reply #1 on: 29 December 2012, 12:50:18 »
Do you have the car pass? That will have the lock code, allowing you to get new barrel from a dealer.
You will also need it for code to program the key, I just bought new fob (minus blade) from a dealer for £31+vat (on trade) Apparently the eBay ones are crap in terms of build.
Re: MV6 ignition
« Reply #2 on: 29 December 2012, 12:52:33 »
Actually scratch that, you can keep same key, just get new barrel, which will match current key. If you get it from dealer along with code  :y
cwill144
  • Oxford
    • 1998 MV6
Re: MV6 ignition
« Reply #3 on: 29 December 2012, 12:54:55 »
so nothing will need to be reprogrammed then?
Re: MV6 ignition
« Reply #4 on: 29 December 2012, 12:56:28 »
Depends, if you have the car pass? Its a credit card sized thing with radio code, ect on it. If not can be around £30-50 to get it from dealer.
With that, it has a mechanical code for the key. So you can get a new barrel ordered, which will work with current keys.
cwill144
  • Oxford
    • 1998 MV6
Re: MV6 ignition
« Reply #5 on: 29 December 2012, 12:58:53 »
Yes I have the car pass (it also has the audio codes on it) have you any idea of the price of a barrel from a dealer?
Re: MV6 ignition
« Reply #6 on: 29 December 2012, 13:00:35 »
Sorry no  :( - Someone else with TIS or TradeBook handy might be able to assist.
Worth joining Autobahnstormers though, to get trade prices.  :y
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: MV6 ignition
« Reply #7 on: 29 December 2012, 13:06:20 »
To get you out trouble just get a another Barrel and Key, use the old Ignition Loop around the barrel and the old Transponder from the old key.
cwill144
  • Oxford
    • 1998 MV6
Re: MV6 ignition
« Reply #8 on: 29 December 2012, 13:09:49 »
Is the key transponder in the blade part of the key? so if tie wrap it to the new barrel I use another barrel and key?
zirk
  • Epping Forest
Re: MV6 ignition
« Reply #9 on: 29 December 2012, 13:12:34 »
Could do that but just swop the Transponder from the old key, they just pull out (sometimes a little glue is used).
EDIT; just to check what year is the car.
« Last Edit: 29 December 2012, 13:14:58 by zirk »
Re: MV6 ignition
« Reply #10 on: 29 December 2012, 13:13:28 »
Transponder is in the blade part, can separate that from fob & as long as its not been glued in will be swappable.
I'd wait until you know how much a dealer one is really, see which is most cost effective  :)
cwill144
  • Oxford
    • 1998 MV6
Re: MV6 ignition
« Reply #11 on: 29 December 2012, 13:15:59 »
How can the transponder be removed from the key? as advised will see how much the dealer wants first. thanks for the help
zirk
  • Epping Forest
Re: MV6 ignition
« Reply #12 on: 29 December 2012, 13:18:21 »
They normally just pull out from the Blade Plastic bit.
Re: MV6 ignition
« Reply #13 on: 29 December 2012, 13:23:34 »
If you have the "horseshoe" type key, transponder chip here
  • Auckland
    • Mazda MPV
Re: MV6 ignition
« Reply #14 on: 29 December 2012, 13:32:11 »
Does the barrel actually provide the detents between switch positions? or is it the switch itself :-\
I would have the cowl off and have squint at the switch before condemning the lock barrel.
Page created in 0.04 seconds with 20 queries.
