Author Topic: puddle in rear footwell  (Read 985 times)
gpenny07931
  • greenock (scotland)
    • omega 2.2cd auto
« on: 29 December 2012, 13:05:37 »
Found a nice puddle in the rear passenger side footwell. Have no idea where the water is coming from as the door seals all seem fine and dry. Anyone had a similar problem?
Re: puddle in rear footwell
« Reply #1 on: 29 December 2012, 13:07:52 »
How is the front passenger foot well? If thats wet check the drain under the scuttle on the passenger side, where the pollen filter is. Water should drain straight out. Make sure its clear.
If front is dry, check for any holes in the chassis, on mine, one of the lugs underneath for the carpet clips came clean off at some point, letting water in from below:
gpenny07931
    • omega 2.2cd auto
« Reply #2 on: 29 December 2012, 13:09:49 »
The front is quite damp aswell but rear is worse. I will give that a check now. Cheers.
