Author Topic: Flashing spanner light . . help please  (Read 3014 times)
Big_Al
« on: 30 December 2012, 13:23:06 »
Hi guys,
              been having intermittant problems with car cutting out & sometimes not starting .
Car would not start last night . Left it for half hour & it then started first time as normal .
The car just cut out after 3 miles again  this morning & would not re start.  Have now got a constant flashing spanner light when turning on ignition.
Have towed car home .
Is this pointing towards the imobiliser / key ?
Cant get codes out as spanner light is constantly flashing  :-\ :-\
Or any other suggestions please . :-\
TIA Al
« Last Edit: 30 December 2012, 13:26:33 by Essex Big Al »
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
Re: Flashing spanner light . . help please
« Reply #1 on: 30 December 2012, 13:42:27 »
The flashing light does usually mean that the immobilizer can't find the transponder chip, try adjusting the steering wheel up and down to see if that helps (maybe a loose connection on the pickup around the ignition barrel).
Do you have a spare key you could try?
Brikhead
  • West-Mids.
« Reply #2 on: 30 December 2012, 13:43:42 »
Also worth checking the plugs on the main engine e.c.u. in the relay box under the bonnet...
Big_Al
« Reply #3 on: 30 December 2012, 13:54:37 »
Ok guys , have taken key apart . Presume "chip" is the small grey piece wedged in the side of the horseshoe of the key blade .
Was very dusty & dirty in there . Have cleaned it all out with an artists brush & re assembled .
tried key in ignition  . . . spanner light has stopped flashing  .  .  car started on the button  .  . .   happy days  :y :y :y :y
thanks for your replies fellas ,   all running ok again now .
i must try & get another key though as only got the one when I brought the car  :( :(
Big_Al
« Reply #4 on: 30 December 2012, 14:32:57 »
Spoke too soon  . . .  as said car started fine  . . tried it several times   . . .   got changed to go out & now it won't start again  >:(
no flashing spanner light now though  . . so have done pedal trick  & have 2 codes  . .    0560      & 0335
0560 is probably where i flattened the battery trying to start it  .     0335 is crank sensor i think .
Looking like a new crank sensor  then  . . would you agree ?
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #5 on: 30 December 2012, 14:33:48 »
Could be wrong here but seem to remember if the ECU doesn't recognise the Transponder on Start Up then you need to go through the motions of removing Key locking Door and unlocking again before it will start again with a recognised Transponder chip, If it that helps.
Big_Al
« Reply #6 on: 30 December 2012, 15:08:44 »
Tried that  . .   yep  :y :y  started straight away . ::) ::)
Not at all sure of whats going on here .  will see if it plays up again & wont start . .  if so will get out lock doors , open again & try again .
To sum up whats happened so far ...  cleaned out key chip ,then  spanner light no longer constantly flashed & car started straight away .
re started it several times  . . all ok .
Went to go out about half hour later  . .  .would not start but no flashing spanner light .
Just tried Zirks suggestion of locking & unlocking doors & car started straight away . ::) ::) ::) ::)
What is going on here   :-\ :-\ :-\ :-\
« Reply #7 on: 30 December 2012, 17:09:53 »
As you got an 0335 then suspect crank sensor Al.  Symptoms now classic crank sensor issues.  Think you seem to have cured the immobiliser issue, and anything further to do with the key is a red herring.  HTH - my opinion ;)
« Reply #8 on: 30 December 2012, 17:51:31 »
If you can get up to me in the morning Al you can borrow my spare sensor for confirmation purposes if it helps. :y
Big_Al
« Reply #9 on: 30 December 2012, 19:44:54 »
PM sent Albs
« Reply #10 on: 30 December 2012, 19:55:16 »
That 0335 would make me nervous taking it anywhere :o :o
Crank sensor has to be the first point of call ;)
Big_Al
« Reply #11 on: 30 December 2012, 20:16:22 »
My thinking too LD .   Already had to tow it home this morning :'( :'(
 But may have arranged to use/borrow a known good one from a local  Oof member  to try first .
Nothing in service history of the original being changed  . . so well due a new one  . . car is on 125k
« Reply #12 on: 01 January 2013, 19:34:54 »
Make sure the little chip is not moving when the key is in your pocket !!  dab of superglue solved the problem for me ...exactly as you state... and the chip was simply moving inside the key :)
Big_Al
« Reply #13 on: 01 January 2013, 19:57:55 »
Thanks, Entwood,
I think this was the problem all along . . .    took key apart  & cleaned it out . The  "chip"  seems to be shaped with a rounded corner
that follows the profile  of the horseshoe part of the key where it sits .
The chip was possibly the wrong way round  (As I see it anyway) allowing it to move .
Re assembled &  everything working fine . Have not done it yet but  Super glue seems a good idea.
Question:   if the  imobiliser sensor  in the barrel loses contact with the key "chip"  whilst car is running/driving  . .  would this cause the engine to cut out .
Or does imobiliser/key chip recognition  just apply on initial start up ?
« Reply #14 on: 01 January 2013, 21:51:08 »
You got an 0335 and still having the starting problem since "sorting" the immobiliser issue - as I said earlier Al - "Symptoms now classic crank sensor issues.  Think you seem to have cured the immobiliser issue, and anything further to do with the key is a red herring."  IMO!
