2.0l auto diplomat to 3.0l auto
Started by The Red Baron, 31 December 2012, 19:02:33
Quote from: Murph on 01 January 2013, 18:39:06
That's been done too!   :y
That's a BMW 5 litre V12 in a Carlton estate!
Very nice  :)
The 3.0 V6 engine management system doesn't rely on that many connections into the main body loom, so I would transfer engine, engine loom and ECU with all ancillaries as one. You then need 12v feeds, immobiliser, diagnostic connection, fuel pump wiring mated with the car's loom, which shouldn't be too hard.
Engine ECU might miss the speed signal from the ABS and perhaps the torque reduce signal from the TC/Autobox but as long as that's wired in the inactive state it shouldn't cause a problem.
bigegg
you'll need to swap the ar25 gearbox in the dippy to an ar35, cos otherwise you'll break it.
My 24V diamond had an ar25 fitted, and it only lasted about 5,000 miles :.(
Carpe Incendium
2woody
this is all reasonable easy.
you'll need to replicate the Omega inside the Carlton if you get whta I mean.
this means that the engine, engine controls, auto box and controls and the ABS must be transferred. But as long as you make sure you carry across all of the parts then you'll be fine.
Quote from: bigegg on 01 January 2013, 22:55:57
Oh, no driver involvement? Seems like an ideal opportunity to add that. ::)
Quote from: Kevin Wood on 02 January 2013, 00:59:23
If you're to do summat, then you might as well do the whole job ;D
The Red Baron
Quote from: 2woody on 01 January 2013, 23:43:33
cheers woody, i will look into this.  :)
