2.0l auto diplomat to 3.0l auto
Started by The Red Baron, 31 December 2012, 19:02:33
The Red Baron
heres a little project i may be thinking about. dropping a v6 auto into a 2.0l auto dippy. what would peeps think of that.
what sort of problems would i be looking at here?.  :)
Diplomats are nice cars but it seems a lot of work plumbing in a V6 when you could just put a gold top or 24V in and be able to source most parts to do so easily enough.
The Red Baron
Quote from: VXL V6 on 31 December 2012, 19:46:53
i understand what your saying andy, as i will have all the running gear from my mv6 saloon spare i was thinking. ;)
biggriffin
hardest part will be the ignition, v6 is coil pack carlton is dizzy, might need to talk to the LC boys on ABS, there was a chap in the manta owners who put a 2.5 in a manta a few years back.
Hoof'land storeman.
Quote from: The Red Baron on 31 December 2012, 19:02:33
Sounds good to me  ;)
Auto Addict
Quote from: EMD on 01 January 2013, 11:26:57
Sounds headache stuff to me ;D
I like red cars
If you search German Ebay with the words Opel Omega Irmscher there's quite a selection of 4.0 straight six engines/parts 8) if you're to do summat, might as well do it properly :y
Murph
It's been done but it has it's difficulties.
The engine will drop onto the standard 2.0 subframe but will rub a little on the bulkhead.
The looms can be spliced in but the fuel computer will not work.  It's likely though that the 2.0 loom will not have the pickup for the speedo, so you will either need to use the 2.0 box and cable speedo or use a dash loom and clocks from a six cylinder carlton.
The brakes and front struts will bolt straight in so no probs there.
Straight 6 in an omega is the other option  :y
The Red Baron
Quote from: Murph on 01 January 2013, 16:21:22
mmm interesting, dont spose you know who did it per chance murph?.
Murph
#10
It was this one.
The chap that built it goes by the name of 'Mantaray' on a few forums, and has posted a link to CRC Classics in Coventry (www.crclassics.co.uk). Apparently it was built using parts from a previous V6 Manta conversion so probably the same as the one mentioned above.
Looking at the space in front of that engine I would be thinking at least 3 litres and two cylinders bigger :y
Murph
That's been done too!   :y
That's a BMW 5 litre V12 in a Carlton estate!
The Red Baron
