Author Topic: TICK OVER PROBLEM  (Read 1421 times)
isywizz
  • west sussex
    • omega 2.6 v6
TICK OVER PROBLEM
« on: 02 January 2013, 17:15:14 »
I own a 2001 omega 2.6 v6 which ticks over fine most of the time but sometimes revs to 2000rpm but when u blip the thottle it goes back to idle again. Can anyone tell me why this is happening?
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
Re: TICK OVER PROBLEM
« Reply #1 on: 02 January 2013, 17:38:35 »
Does the fbw 2.6 have an idle control valve,? if so it needs a clean, see the maint guides to clean, if not then it will have tps in the throttle body, it might be time to remove the throttle body and clean with carb cleaner and refit
Also check for air leaks in the vac hoses and intake system..
« Last Edit: 02 January 2013, 17:41:03 by ffcgary1 »
Jaguar XJ6
« Reply #2 on: 02 January 2013, 17:44:36 »
No icv on dbws mate
ffcgary1
  • Mitcham,Surrey.
« Reply #3 on: 02 January 2013, 18:07:00 »
Ah thought as much, thats why i offered the alternative.
See i am learning slowly :y
Jaguar XJ6
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #4 on: 02 January 2013, 19:54:07 »
It would be worth getting someone with Tech2 to get some readings.  Could be a sticky Throttle Peddle - They are DBW (Drive By Wire) on the 2.6/3.2.
« Reply #5 on: 02 January 2013, 20:07:30 »
The DBW V6's do hold the revs when blipping. If its excessive, I'd clean the TBs and breathers...  ...actually, I'd clean them anyway ;)
« Reply #6 on: 02 January 2013, 23:45:30 »
I've seen 2.6s do this when the MAF is on its' way out before. Worth getting the live data from a Tech 2 to check if the MAF output is reasonable.
« Reply #7 on: 03 January 2013, 00:02:44 »
Was going to say maf or air leak personally.
Pedal trick? This doesn't work with a dbw fault ime.
« Reply #8 on: 03 January 2013, 01:02:09 »
Try it with maf disconnected mate - if its better suspect maf ;)
Page created in 0.024 seconds with 16 queries.
