is cleaning your injectors this easy?
Started by Webby the Bear, 02 January 2013, 23:16:02
Quote from: Webby the Bear on 02 January 2013, 23:40:24
if that don't work i'm going for some ''start, you bastard'' hahahaha
http://www.youtube.com/watch?v=cY1YndLmbXQ
;D ;D  The first time I saw it, I laughed for minutes ;D
Quote from: Kevin Wood on 05 January 2013, 09:53:19
Quote from: TheBoy on 05 January 2013, 09:47:32
Ultrasonic is the proper way.
Wonder if bro will let me borrow one of his jewellery cleaners ::)
Indeed, and more importantly a decent service will give you a before and after report on flow rate and spray pattern so it will tell you if you did have a problem.
I've only bothered on a rare set I salvaged from a scrap yard, previously fitted to a Volvo with intergalactic miles. Even then, the injectors weren't too bad in the "before" report. They were spot on manufacturer's spec in the "after", though. I certainly wouldn't bother on a car that's getting regular use unless I suspected a problem.
if the car starts hot starting problem as I experienced discard all of them..
I did used to pop in some Forte once a year when I ran on petrol.  Probably still should, esp as the injectors now get little use.
I used to use Redex on the tractor, to help combat Asda diesel ;D
tigers_gonads
Tbh, with the amount of additives in petrol nowdays i'd have thought these fuel treatments would have been extinct  :-\
Then again, I do tend to use the full travel of the accelerator  :-X :-X
I was told though to get the injector needles re ground after 100,000 miles or so when I had the tractor  :-\
True or false ?
