Author Topic: few problems  (Read 2078 times)
vec666
  • scotland
    • omega 2,2 auto
few problems
« on: 03 January 2013, 22:38:18 »
hi everyone, got 2003 2.2l petrol needing the crankshaft sensor replaced how hard is it to do and i am going to replaced the rear pads how hard are they thanks
Re: few problems
« Reply #1 on: 04 January 2013, 06:40:56 »
Rear pads are a ten minute job, including a cuppa :y
Not sure about the crank sensor as I've never had a 2.2, but ought to be fairly accessible. :-\
Allow an hour for the lot, including lunch :y
b4ndit
Re: few problems
« Reply #2 on: 04 January 2013, 08:36:45 »
Hi and welcome :y
Re: few problems
« Reply #3 on: 04 January 2013, 09:51:49 »
On a 2.2 it's far more likely to be the cam sensor, though. What are the symptoms?
vec666
  • scotland
    • omega 2,2 auto
Re: few problems
« Reply #4 on: 04 January 2013, 20:38:51 »
its the wire that gos round the timing belt, murder trying to get the timing cover off broke the bottom bit will i need a new cover thanks
Re: few problems
« Reply #5 on: 04 January 2013, 21:30:04 »
 ::) ::) ::) ;D ;D ;D ROFL!
Actually it's not too bad if you've got an 8yr old granddaughter with hands as slim as Tunnies! ;) (I have :y)
Re: few problems
« Reply #6 on: 04 January 2013, 21:32:10 »
Re: few problems
« Reply #7 on: 04 January 2013, 21:34:33 »
Sensor access is challenging as its obscured by the aircon pump bracket
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: few problems
« Reply #8 on: 04 January 2013, 21:38:58 »
If I am reading the guide correctly dont you re-route the crank sensor round the side of the engine block, cut the old sensor end off and pull up to get rid?
RIP Paul Lovejoy
Re: few problems
« Reply #9 on: 04 January 2013, 21:41:23 »
its a 4 pot Desmond so a different beast
Webby the Bear
  • Northampton
Re: few problems
« Reply #10 on: 04 January 2013, 21:43:44 »
oh ok, fair enough. I just assumed they'd be in roughly the same area.  :)
RIP Paul Lovejoy
vec666
  • scotland
    • omega 2,2 auto
Re: few problems
« Reply #11 on: 04 January 2013, 21:52:05 »
going to attack it tomorrow if it stops raining
vec666
  • scotland
    • omega 2,2 auto
Re: few problems
« Reply #12 on: 05 January 2013, 23:28:34 »
try it today and spotted that there oil dripping still
