Pages: [1] 2 3  All   Go Down
Author Topic: codes  (Read 6286 times)
b4ndit
codes
« on: 04 January 2013, 10:46:19 »
Hi,
can anyone point me in the right direction as to the cure for these codes please
P0155 O2 Sensor Heater Circuit High Voltage (Bank 2 Sensor 1)
P0300 Random/multiple cylinder misfire detected
P0306 Cylinder 6 Misfire Detected
many thanks in advance :y :y
Re: codes
« Reply #1 on: 04 January 2013, 10:49:44 »
For 300/306, check plugs for oil/water on the 2-4-6 bank, worth checking 1-3-5 as well.
Is your EML on?
b4ndit
Re: codes
« Reply #2 on: 04 January 2013, 10:53:15 »
no eml on did come on then went back off did cam covers aug last year with genuine ones from andyc also changed plugs as well just happened this morning when swmbo went to the shops
Re: codes
« Reply #3 on: 04 January 2013, 10:54:24 »
how old are the plugs, also how many miles on coil packs?
b4ndit
Re: codes
« Reply #4 on: 04 January 2013, 10:55:36 »
plugs aug last year and coil packs don't know if original then 130k :y
Re: codes
« Reply #5 on: 04 January 2013, 11:07:45 »
Check for water around no 6 plug well due to a leaky scuttle.
b4ndit
Re: codes
« Reply #6 on: 04 January 2013, 11:47:31 »
just got the coil pack off  and no water or oil in or around the plugs plugs look ok can't see anything on the coil pack either should I change the plugs to eliminate them any suggestions welcome thanks :y
v6man54deg              Geffd
  • Wirral Merseyside
  • V6 man
Re: codes
« Reply #7 on: 04 January 2013, 12:17:47 »
you could always swap the plug to another bore to see if the problem misfire follows it - could be the actual coil pack itself with it coming up random misfire - check the condition of the rubbers that fit over the plugs - often they get damaged if its not removed correctly - there is a special tool to remove them - i just use two larger bolts to do it
have got a brand new one in the garage but just checked and its  1-3-5 bank
V6 problems solved : Worked at the V6 Engine plant for 13 years on durability testing and warranty issues, this job included many trips to Russelsheim, Trollhattan, Michigan, Atlanta,keiserslaughtern.
b4ndit
Re: codes
« Reply #8 on: 04 January 2013, 14:04:50 »
if I need the coil pack and you are selling it how much would you want for it :y
Re: codes
« Reply #9 on: 05 January 2013, 09:34:02 »
Might be worth check bank 2 trims, given the codes from bank 2 lamda.
Visually inspect the missing cylinder coil pack. Any signs of expansion, or rust in the cracks that may appear, is a bad sign...
b4ndit
Re: codes
« Reply #10 on: 05 January 2013, 09:43:14 »
no cracks  expansion or rust changed the plugs now seem to be fine. also who's the best to get the trim checked :y or closest to chester
Re: codes
« Reply #11 on: 05 January 2013, 09:45:11 »
I think Mr Greedy has the capability? Drop him a PM :y
b4ndit
Re: codes
« Reply #12 on: 05 January 2013, 10:02:13 »
Thanks TB will do :y
    • E250 Est / Elroq
Re: codes
« Reply #13 on: 05 January 2013, 15:46:00 »
And replied :y
b4ndit
Re: codes
« Reply #14 on: 05 January 2013, 20:07:13 »
Big thanks to Jimbob for your help tonight many thanks all sorted now ;D ;D :y :y
Pages: [1] 2 3  All   Go Up
