Coolant loss ?
Started by tomh23, 04 January 2013, 23:11:46
tomh23
Doing some check's on the Omega today and on checking the coolant bootle was very low ( no warning on MID which i find strange as its picking up washer low) anyways topped her up and decided to have a look on here as ive had no luck with cars and coolant loss lol.  Found the HBV post on here as didnt even know that existed so thought great ill go check that and hopefully job done................nope thats all fine and dry  :'( Ive ran with A/C on, heater on full and low to try make it leak but nothing as dry as anything.  There are no signs of any leaks on the under tray.
So im at a loss, the car doesnt overheat, the heaters are hot, the floor is dry, there is no gunk on cap and coolant doesnt show any signs of oil, oil looks fine.
How are the 2.2dti for Head gasgets and is there anything else I can check.
I pull a car transporter trailer and have not checked the water for a while could towing cause water loss over time ?
Check the neck of the bottle for tiny cracks, and the seal in the cap for perishing, as either can cause vapour loss under pressure, this is similar to the water "evaporating" and will show a slow loss of fluid.
If it is a faster loss it is possible, sometimes, to hear a hiss from the cap area when the system is up to full temperature and pressure.
tomh23
Thank mate, no hissing @ temp but will double check in daylight.
Webby the Bear
When was the last time you checked it/topped up?  :)
RIP Paul Lovejoy
tomh23
Last time was November time lol
Webby the Bear
big miles in that time???
RIP Paul Lovejoy
tomh23
Not really, ive towed a few cars / shells and other than my usual work and back.
Im topped up now and have to take a Caravan down to Northampton next weekend for the Father in law so will be a good test.
Webby the Bear
then i'd follow entwoods advice mate  :y
RIP Paul Lovejoy
martin42
This is the reason you must check levels every week and never rely on sensors to tell you,takes less than 2mins,compared to expensive garage bills,which can be prevented,my car is checked every week even if it hasnt been driven,and always before a long drive.
omegod
Have a look at the rad drain screw bottom right as you face the car, mine was weeping and I could see it after parking up after a run. Also I had a hairline crack in the plastic on the top left of the rad which would evaporate as it leaked through, bugger to find but fixed/bodged with a blob of araldite
Quote from: tomh23 on 04 January 2013, 23:11:46
.... and on checking the coolant bottle was very low ( no warning on MID which i find strange as its picking up washer low) anyways  ...
how would there be a connection between the two?  ??? ??? ???
Quote from: Andy B on 05 January 2013, 20:52:42
coolant bottle sensor failed?
biggriffin
Quote from: chrisgixer on 05 January 2013, 21:22:04
coolant bottle sensor failed?[
bought one last month 90500223 £40.00inc vat on TC.
Hoof'land storeman.
Quote from: biggriffin on 05 January 2013, 23:16:24
it gets very low before the fault shows. And hbv , one of the failure modes is to only leak with ac on.
I know nothing about the Dti, but on the v's any coolest leak is after evident around the bell housing, or there a cracked rad of course.
As with most hot water leaks, including house hold central heating, the liquid often evaporates off before the leak is found, up to a point of course. So your looking for chalky pink residue, if you have red coolant for instance.
When mine leaked it would only do so over night , found to be the connections on the rad itself plus the drain screw was loose  :y
