I love my car a bit more today
Started by SMD, 05 January 2013, 20:04:47
SMD
Finally cured that gearbox/lever squeak. The culprit was the bottom of the small lever was rubbing on the metal gear steps (under the gaitor). Now I need to sort out the rear seat squeak. How does the rear seat come off again?  :y
Johnny English
Well done mate  :y Rear seat won't come off if you let it to be there where now it is haha  ;D  ::) ::) ::) good luck (lack  ::) ) with sorting out bud !  :y
C20NE - X25XE
SMD
I can see two plastic levers under the rear seats. Do I need to pull the levers down or sideways? I don't want to snap them off
joshwyatt
Pull them towards the front of the vehicle, I think it'd almost be impossible to break them. Once done, the reat seat base can just be taken out, but with rear heated seats be mindful of the wiring.
biggriffin
as josh says just a good pull on the 2 levers under neath, to refit push the back down and in and then locate the lugs into the font holes should stop squeaking then.
Hoof'land storeman.
