Author Topic: leaks  (Read 1798 times)
vec666
  • scotland
    • omega 2,2 auto
leaks
« on: 05 January 2013, 21:27:43 »
changed the rocker gasket and still oil leaking at the back onto the gearbox help thanks
Re: leaks
« Reply #1 on: 05 January 2013, 21:29:17 »
Oil cooler bolts? In the v, under plastic wedge.
Re: leaks
« Reply #2 on: 05 January 2013, 21:31:24 »
Not on a Desmond ;) ;)
Did you use genuine gasket and did you clean the breathers?
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: leaks
« Reply #3 on: 05 January 2013, 22:32:23 »
and did you put the sealent in the right place and not over tightend the bolts?
Hoof'land storeman.
vec666
  • scotland
    • omega 2,2 auto
Re: leaks
« Reply #4 on: 05 January 2013, 23:26:50 »
what breathers thanks
Re: leaks
« Reply #5 on: 05 January 2013, 23:31:07 »
Search & you shall find: http://www.omegaowners.com/forum/index.php?topic=90528.0
Was a genuine gasket used? Was correct sealant used in the right place?
As per: http://www.omegaowners.com/forum/index.php?topic=90597.0
vec666
  • scotland
    • omega 2,2 auto
Re: leaks
« Reply #6 on: 05 January 2013, 23:36:43 »
were does the sealant go
Re: leaks
« Reply #7 on: 06 January 2013, 00:45:29 »
Where it says in the guide linked to above your post ;)
Re: leaks
« Reply #8 on: 06 January 2013, 08:43:20 »
It says where it goes in the link I provided
Re: leaks
« Reply #9 on: 06 January 2013, 09:17:12 »
Do the Desmonds have the halfmoons at the back of the head :-\
Overlooking that on the V6 makes for quite a mess :-X
Re: leaks
« Reply #10 on: 06 January 2013, 11:16:16 »
You are right there al! ::) ::) ;)  I once overlooked that and didn't ensure the half moon of the seal for the right bank was fully seated.   Result loads of oil down the back of the engine, clouds of blue smoke, and a repeat job of fitting one cam cover seal! :P :P
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
Re: leaks
« Reply #11 on: 06 January 2013, 13:44:45 »
Seems no sealant used then ::)
Jaguar XJ6
