Pages: 1 ... 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 ... 24   Go Down
Author Topic: LPG fitting SOuthampton  (Read 48898 times)
0 Members and 3 Guests are viewing this topic.
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
Re: LPG fitting SOuthampton
« Reply #135 on: 21 January 2013, 20:58:44 »
This weekend:
- bowling fri night
- triathlon training camp on sat
- sunday, sushi makingclass and cirque du soliel
plus I might even get a birthday shag off the missus so you are waaaaaay down on the list buddy, sorry ;D
« Last Edit: 21 January 2013, 21:05:39 by Guffer »
« Reply #136 on: 21 January 2013, 21:27:47 »
This weekend:
- bowling fri night
If she's got any energy left :-X ::)
« Reply #137 on: 21 January 2013, 21:28:36 »
Got it!!! Valtek nozzles  :P :P :P
So tonight I fitted up the tank and played around with the tank frame. The bolts which hold the frame to floor, do they have to have nylock nuts fitted?
Not specifically, IIRC, but if you are mounting it where most of us have the bolt goes through a box section, so you can't do it up tight without crushing said box section. In this case, nyloc nuts and/ or a spacer inside the box section are required.
I used Nylocks and spring washers ;)
doz
  • Southampton
  • LC,GSi Carlton,Omega Elite
« Reply #138 on: 21 January 2013, 22:03:02 »
Another question. Does the filler pipe which is being fitted to the offside rear quarter need to be run inside the plastic 30mm hose like the delivery hose?
« Reply #139 on: 21 January 2013, 22:36:37 »
Yep, unless you're using a JIC (hydraulic type) pipe in which case it just needs rubber boots both ends. If you do that you may be told to run a second vent pipe anyway.
doz
  • Southampton
« Reply #140 on: 21 January 2013, 22:41:29 »
Second vent pipe? Yep using JIC
« Reply #141 on: 21 January 2013, 22:49:29 »
It's to do with cross section of vent pipe. With a polyflex pipe and too big a cable there isn't sufficient to comply with COP 11  ::) Most inspectors will let it go as it's borderline ;) It's worth a call to whoever you are going to use to inspect it :y
doz
  • Southampton
« Reply #142 on: 21 January 2013, 23:06:17 »
I see. My plan is to use a loop like the guide you wrote so I can route the feed pipe down the offside of the car and also have the fill pipe entering the offside of the gas tight box. If I use the 30mm sleeve on the filler pipe even though it has JIC pipe and is going to a quarter panel filler would that count as a second vent pipe? Or does it have to vent to under the vehicle as well?
« Reply #143 on: 21 January 2013, 23:15:36 »
Any vent pipe needs a continuous drop to the bottom of the vehicle, so a pipe to a filler won't count (unless it goes out through the floor and back up inside the boot, inside ducting while inside the vehicle. Would be better than nothing, though, and, as said, there's a certain amount of flexibility if you pick the right tester. ;)
It's acceptable to run rubber hose outside ducting from tank to filler as long as it's sealed at each end, but you might end up with too little tank venting, as said.
« Reply #144 on: 21 January 2013, 23:18:41 »
You'll struggle to do that TBH. if you use liquid PTFE (Gas rated) on the outlet valve on the tank you can turn it to avoid the loop. Experience has told us that liquid PTFE is better than tape :y
Have a quick chat with them... Or do the calculations. I'm sure 1 pipe and the cable is ok :-\
doz
  • Southampton
« Reply #145 on: 22 January 2013, 07:06:23 »
Can't turn it. Solenoid on valve won't fit in the box if I do.. Also I was going to run the cable inside the car. This is just an personal preference so won't be going down the vent pipe just leaving the actual gas feed.
« Reply #146 on: 22 January 2013, 09:40:05 »
Great idea :y But how do you intend to get it into the gas tight box? ???
Gaffers
« Reply #147 on: 22 January 2013, 11:04:12 »
Easier if you follow the gas delivery line  :y
doz
  • Southampton
« Reply #148 on: 22 January 2013, 11:46:40 »
Box has 4 ports. Plan is to use  1 for filler.   1 for feed bike. 1 will have blank fitted and the last one for cables. I have some 4 core cable which fits tightly in one of rubber cups and I can make leak free.
« Reply #149 on: 22 January 2013, 12:01:26 »
Be prepared to have to prove to the inspector it's leak free ;) They don't like it!
Far easier to run the wiring with the feed line ;)
Pages: 1 ... 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 ... 24   Go Up
