Pages: 1 ... 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24   Go Down
Author Topic: LPG fitting SOuthampton  (Read 48550 times)
0 Members and 4 Guests are viewing this topic.
Re: LPG fitting SOuthampton
« Reply #240 on: 18 February 2013, 23:45:51 »
Aye. I'm out of ideas. The two last things for me to try are. Gas injector selection and then drilling the jets to 2.5. Will try that tomorrow if Paul is able to tell me his configuration. One last thing. Could the gas ECU be frasseled? but more than anything I need someone else to look now. I'm out of ideas.
Don't drill them any bigger... It's flowing enough gas ;)
I'll check the settings tomorrow as I know your kit is identical to mine ;)
I assume that you're getting clean, viable RPM figures in the LPG software?
« Reply #241 on: 19 February 2013, 00:13:35 »
As said, don't drill them bigger. All these kits we've seen have needed 2.2 nozzles, or there abouts.
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #242 on: 19 February 2013, 07:32:23 »
Is anyone else thinking air leak?  Or am I reading it wrong?
Easy done with all the plugs under the plenum...
« Reply #243 on: 19 February 2013, 08:11:19 »
Can't see it as it's idling ok and goes like a stabbed rat at full chat, just the little throttle openings.
Plus it's fine on Petrol. I'm still leaning towards a HT fault
« Last Edit: 19 February 2013, 08:24:12 by Lazydocker »
« Reply #244 on: 19 February 2013, 08:20:35 »
I'd be happy to take a look, but I'm a bit tied up until after this weekend.
doz
  • Southampton
  • LC,GSi Carlton,Omega Elite
« Reply #245 on: 19 February 2013, 10:02:04 »
Kev you saviour!!!! Let me know when you are free and I'll bring it up.  :y :y
« Reply #246 on: 19 February 2013, 10:55:30 »
Here you are Dave, a screen shot of the 2 settings pages on the software :y
Screen Shot by lazydocker, on Flickr
Mind, I've just noticed I haven't selected a Lambda Type... Must do that next time I plug in (probably 6 months or so ::))
« Last Edit: 19 February 2013, 10:57:12 by Lazydocker »
doz
  • Southampton
« Reply #247 on: 19 February 2013, 11:08:10 »
Interesting. Can they run without the Lambdas? I have different temp sensor selected and I think my injectors are different.
« Reply #248 on: 19 February 2013, 11:22:10 »
Yep, although mine are connected up and it does monitor them... I must have missed the selection after the latest firmware update because it never used to be there ::)
The temp sensor is a bit of trial and error to find the one that gives the most accurate reading compared to the car temp ;)
doz
  • Southampton
« Reply #249 on: 19 February 2013, 11:28:10 »
Hmmm. My software version is 6 something. I couldn't get the interface to work with 9. Couldn't find the drivers.
« Reply #250 on: 19 February 2013, 11:31:58 »
Right... You might have to update the firmware, then go to AC 7, then update again and go to AC 9 ;)
If you can't get them I'm sure Kev will, like me, have all the versions installed still as a just in case ;)
Gaffers
« Reply #251 on: 19 February 2013, 17:26:05 »
Ahem......... do you really want to be admitting to that on here?  ::) ;D
« Reply #252 on: 19 February 2013, 18:43:25 »
Oh Lordy, how many versions behind is my MV6 now then ;D
Doz, dont drill to 2.5, its too big.
« Reply #253 on: 19 February 2013, 18:44:20 »
Fek knows what mine is on  :D
« Reply #254 on: 19 February 2013, 18:50:00 »
You don't have a Stag 300 Plus ;)
Pages: 1 ... 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24   Go Up
