Pages: 1 ... 15 16 17 18 19 20 21 [22] 23 24   Go Down
Author Topic: LPG fitting SOuthampton  (Read 48547 times)
0 Members and 4 Guests are viewing this topic.
Re: LPG fitting SOuthampton
« Reply #315 on: 25 February 2013, 21:36:31 »
90 litre.  ::)
Don't think I've seen an Omega with 3 straps, inc 100l tanks
Yes you have... My saloon ;)
If you read COP11 it comes down to the width of the bands. Technically speaking 30mm bands you only need 2. Any narrower and you need 3. I think this guy is being a bit of a stickler but he looked under the bonnet and was happy with what he saw. When I go back I'll print off a copy of the COP11 and if he tries to pick it up again on anything daft I'll wave it under his nose. Thing is I bet if I go some where else they'll just pick it up on something else. I guess it's a bit like MOt's you never know what the testers like. Where I go for them everybody complains the MOT guy is a right B'stard but I get on really well with him.
That's unlucky but, at the end of the day, it's your own fault as you had COP 11 to read ::)
But I will apologise as I should have highlighted it for you :-[
doz
  • Southampton
  • LC,GSi Carlton,Omega Elite
« Reply #316 on: 28 February 2013, 19:41:43 »
New straps turned up. New straps sent back. I ordered the wrong ones  :-[ :-[
« Reply #317 on: 28 February 2013, 21:12:01 »
Oppps ;D
doz
  • Southampton
« Reply #318 on: 01 March 2013, 13:27:08 »
Now have right straps. Have some concerns. I asked Tinley what was required for an in boot tank and they said two straps 32mm wide. Which is what I've got. Now the tester said he wanted 3 straps possibly 4. Do you get the feeling he's being a pain in the arse?
« Reply #319 on: 01 March 2013, 16:12:54 »
The Company that did my Inspection were very nit-picky imo but my boot tank (90ltr) has only two 32mm straps and these weren't even commented on as they are the 'Industry Standard' for that size cylinder, so yes, I would say your bloke is being a PITA unnecessarily! ???
« Reply #320 on: 02 March 2013, 00:34:07 »
Not got COP on my phone but off the top of my head the requirement is 2 of 30mm minimum or 3 of 20mm minimum. Take the table along and if he gets funny then wave it at him ;) I did on a few points when mine was inspected ::) But they don't like being told they should look more closely at their own standard of work before trying to incorrectly pick holes in mine :-X ::) :D
doz
  • Southampton
« Reply #321 on: 04 March 2013, 10:23:44 »
Right straps done. Now a little question for ya. When the car flicks to gas the temp gauge in the car is normally around the 55 mark. It's fine while driving but when I come to a stop the engine hunts on idle by around 500 RPM. Now it will keep doing this till the engine reaches around the 80 mark on the temp gauge. Any ideas?
« Reply #322 on: 04 March 2013, 10:28:24 »
They do tend to do that on this kit. I think Kev suspected the injectors range of performance, but not sure.
Mine is the same anyway. I haven't bothered to look into it any further. Tbh.
« Reply #323 on: 04 March 2013, 11:09:04 »
It hunts on petrol too, but not as noticeable ;)
Only real solution is to up the swtchover temp or live with it :y
doz
  • Southampton
« Reply #324 on: 04 March 2013, 13:08:09 »
I'll live with it then  :y Right hopefully the final question. What does the certificate look like now? Is it just an on line registry? Or do I still get a paper version? My insurance company weren't very helpful they didn't seem to understand what was required  ::)
sassanach
  • trowbridge
« Reply #325 on: 04 March 2013, 13:14:41 »
if it hunts on idle then check all your vacuum pipes, you have a leak.
doz
  • Southampton
« Reply #326 on: 04 March 2013, 13:20:44 »
Pipework all good. Doesn't hunt on petrol and only hunts on gas while it warms up.
sassanach
  • trowbridge
« Reply #327 on: 04 March 2013, 13:24:23 »
fairy muff,mine hunted on both,but barely noticeable on petrol,found two leaks and now idles perfectly :y
« Reply #328 on: 04 March 2013, 13:37:18 »
No Certificate per se nowadays Doz, the Installer/ Inspector does it all by Computer. Mine gave me a letterheaded confirmation in case my Insurer asked for it. It stated that on such & such a date, the vehicle had complied with the Regulations and been accepted onto the UKlpg register. I should imagine your chap will/should do the same :y
doz
  • Southampton
« Reply #329 on: 04 March 2013, 13:45:49 »
Cheers. Is there any where you can look up the car on the database?
Pages: 1 ... 15 16 17 18 19 20 21 [22] 23 24   Go Up
