Author Topic: 2003 3.2 manual gearbox oil  (Read 3286 times)
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
« on: 07 January 2013, 17:37:40 »
I think mine needs a top-up, until I get enough time off to investigate the minor dribble - what oil, how much, and how much of a chew is it? Can I do it on axle stands/ ramps? And does the bottle come with a syringey bit to squeeze it in? :y
Re: 2003 3.2 manual gearbox oil
« Reply #1 on: 07 January 2013, 19:10:33 »
EP 80 or better, mobil 75w90.. cant remember how much at the moment..
2woody
  • Northumberland
« Reply #2 on: 07 January 2013, 23:50:37 »
no - it's ATF you need.
yes, I know its not a gearbox oil, but that's what GM siad.
« Reply #3 on: 07 January 2013, 23:55:31 »
My manual Astra used a red oil supplied by my Vauxhall dealer, but it wasn't ATF  :-\
« Reply #4 on: 08 January 2013, 00:40:48 »
Vauxhall transmission oil 19 40 768
Equivalent - FUCHS TITAN SINTOFLUID SAE 75W-80
NOT atf!!
HTH  :y
« Reply #5 on: 08 January 2013, 14:55:37 »
How bizarre. I'll give them a bell tomorrow...
« Reply #6 on: 08 January 2013, 15:31:39 »
There's quite a few manual boxes specifying ATF these days (the Getrag in the M3, most of the Tremec/T5/T56 boxes etc, as an example)..
« Reply #7 on: 08 January 2013, 15:40:54 »
An SD1 had ATF in its manual gearbox IIRC.
But as I suggested & dbug agreed, the manual 3.2 will have a specific oil  in there & not ATF ..... even though it's red.
« Reply #8 on: 08 January 2013, 22:44:46 »
for the cold season mobil 75w90 is better..
2woody
  • Northumberland
« Reply #9 on: 10 January 2013, 21:44:13 »
no surprise here as the Omega box is Getrag, too.
tidla
  • solihull
« Reply #10 on: 10 January 2013, 22:29:46 »
manual box opel 1940 768. which equates to 75w -90
http://seekpart24.com/febi/transmission-oil-32590
« Reply #11 on: 11 January 2013, 12:34:24 »
And get the best synthetic oil you can.
andyc
  • Norfolk
« Reply #12 on: 11 January 2013, 15:17:29 »
The spec is BOT402/SAE75w85 APiGL4 @ £6.08 + VAT per litre
Andy
Thetford. Norfolk
  • Auckland
    • Mazda MPV
« Reply #13 on: 11 January 2013, 16:18:03 »
Never, ever, ever put EP (Extreme Pressure) oil in a synchromesh gearbox. The EP additive is for hypoid gears (crown & pinion gears with offset centres & lots of sliding action).
Once contaminated with EP additive the synchro hubs will never work properly again  :(
« Reply #14 on: 11 January 2013, 16:56:08 »
Not strictly true mate - many older synchro boxes specified EP oils, among them BMC, Jaguar and Triumph (my TR4A is an all synchro box and EP80 specified and used over 90K miles without issue, with EP90 being specified for diff). Your comment may be more relevent to later boxes.
