Side light bulb change
Started by Terbs, 08 January 2013, 21:43:20
Terbs
Hi all,
Sorry to have to ask this question, but I am on a very weak Wi-Fi and cannot access the manual.
How do you change the nearside sidelight bulb. The access panel on top is small and I cannot see how to do it. Does the rad cover have to come off, or the headlight unit removed.
Looking down from the top there is not much room....the battery does not help either.
Thanks in advance :y
Slide battery back as far as possible, should be able to access bulb then
Terbs
Thanks Rob....
I'll have a go in the morning. :y
I had to do mine recently. I'd just take the battery out. You want good access so you don't blunder around and stress the headlight adjusters IMO.
Make sure you have the radio code first, and observe the procedure to silence the incendiary power sounder (if fitted) obviously.
