Author Topic: Is leaking power steering pump a common problem?  (Read 2573 times)
car5car
  • Florida USA
    • 01 Cadillac Catera
« on: 11 January 2013, 21:39:25 »
I am trying to find a leak, coming from power steering pump area.
I don't know if it is pump itself or a hose connection.
Any ideas?
thanks.
01 CADILLAC CATERA 3.0 engine (Omega)
Re: Is leaking power steering pump a common problem?
« Reply #1 on: 11 January 2013, 21:45:11 »
Usually the hose from reservoir related
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #2 on: 11 January 2013, 22:33:42 »
+1. new pipe and jubbilee clip
Hoof'land storeman.
car5car
  • Florida USA
« Reply #3 on: 11 January 2013, 22:41:24 »
Thanks!
« Reply #4 on: 11 January 2013, 22:58:14 »
Jubilee is the oe fitment, but they are the work of saiten. It's possible to over tighten and crack the plastic. Plus, as Master once said so long ago, the rubber pipe goes hard after a while and relaxes, and because the jubilee needs to tighten itself to compensate, it leaks. Where as a spring clip, like those used on the hbv, will hold tension .
So a spring clip is better, if you have one spare, and there is access to get it in position.?
biggriffin
« Reply #5 on: 11 January 2013, 23:01:45 »
bloody spring clips i hate the bloody fings >:(
  should buy the proper tool.
Hoof'land storeman.
« Reply #6 on: 11 January 2013, 23:11:15 »
i believe there is :-\
biggriffin
« Reply #7 on: 11 January 2013, 23:12:56 »
me thinks sealey or machine mart or if feeling flush strap-on ;D
Hoof'land storeman.
biggriffin
« Reply #9 on: 11 January 2013, 23:29:52 »
 i now see why i use mole grips to remove them.
  http://toolstoday.co.uk/shop.php?sec=cat&cat=2146
Hoof'land storeman.
car5car
  • Florida USA
« Reply #10 on: 12 January 2013, 00:06:31 »
I guess jubilee is a clamp with screw? I am learning English English.:)
What is MOT? Safety inspection? Is that once a year?
« Last Edit: 12 January 2013, 00:21:50 by car5car »
kevinp58
  • kent
    • 2002 3.2 elite
« Reply #11 on: 12 January 2013, 00:59:07 »
Yup every year we have to pay the government even more money to have the MOT (Ministry of transport) road worthy test
« Last Edit: 12 January 2013, 01:00:42 by kevinp58 »
car5car
  • Florida USA
« Reply #12 on: 12 January 2013, 02:31:47 »
Lucky me, we don't have any tests in Florida. :y
« Reply #13 on: 12 January 2013, 08:14:31 »
Yes and it shows in the death traps you see on the road sometimes  :y
Abiton
« Reply #14 on: 12 January 2013, 08:40:21 »
I had a PS pump that leaked onto the shaft and pulley.  It was a very slow leak, but would get picked up as an advisory on annual inspections if I didn't give the pulley a wipe down first.  Never seemed to get bad enough to bother actually fixing.
I convinced myself that it wasn't getting to where it was from leaking hose connections.
Page created in 0.078 seconds with 16 queries.
