Author Topic: front fog lamps  (Read 1275 times)
rickyskuse42
  • south wales
    • vauxhall omega isuzu troo
front fog lamps
« on: 12 January 2013, 21:47:18 »
wonder if anyone can tell me to remove the front fog lamps on a 99 model I have to replace the drivers side lamp  as my dozy son drove into the back of my jeep so before I start pulling things apart I thought I,d get some advice cheers
Re: front fog lamps
« Reply #1 on: 13 January 2013, 09:23:25 »
Easiest to remove bumper IME
Open bonnet
Remove grill. 2 or 3 screws hold grill to car, depending if Elite or not.
Remove the trims under headlights - 1 screw, and pesky clips. Remove headlight washer nozzle first if fitted.
Under bumper, 2 plastic clips - prise inner pin out, then entire clip will fall out.
In each wheelsarch, 2 screws - remove.
Behind the (now removed) headlight trims, 2 screws.
Lift bumper off, unplugging each fog light and outside temp sensor as you pull it away.
Re: front fog lamps
« Reply #2 on: 13 January 2013, 17:25:53 »
Never neded to remove bumper on the old 98 Elite Estate - remove set screws (torx, 2 IIRC) holding small grill to the side of fog light and remove small grill.  You will see the one screw holding the fog light in - remove it, slide light unit towards center of car, unplug loom.  10 minutes if screws come off easily :y
As per Haynes, replacement is the reverse of removal - just ensure you locate the fog light securely on its "outside edge" before putting in fixing screw.
rickyskuse42
  • south wales
Re: front fog lamps
« Reply #3 on: 13 January 2013, 20:44:48 »
cheers fellas will take a look tomorrow if I ,m not snowed in  :y
Re: front fog lamps
« Reply #4 on: 13 January 2013, 20:56:08 »
Yup, some (but not all) you can, although often fiddly if you've never had one off before.
