Beaten by a focus
Started by Gaffers, 13 January 2013, 13:30:55
Gaffers
No! Not in the jaaaaaaag ;D ;D ;D
After trying to get the crackshaft pulley bolt off for the last 3 hours with heat and a lot of blood and sweat she is going back together with the old camelt on.  I have a breaker bar on order, I'll give it a go next weekend >:(
Even when I was wrapped around the front of the car to get get maximum leverage, both arms on the ratchet that bastid thing wasn't moving.
Murmhuhguh *mutters something rude about Halfords Autocenters* murmghughugh........
mantahatch
I once bent a 4 foot bar trying to get a crank pulley off a 1.8 1983 vw santana. Last time I worked on an vw.
Shackeng
Is it possible to jack it up and use the weight of the car coming down to move it? I've used this many times in the past. :y
cnj
nothing like 3/4" drive and scaffold pipe !
tidla
Worthy investment is a compressor and a windy gun for such jobs.
plym ian
you need a 22st lump on the end.
I'm available for hire most days ;D ;D
Gaffers
Quote from: plym ian on 13 January 2013, 17:20:46
I'm already 17st and mostly muscle.....going to wait for the breaker bar  :y
Shackeng
Quote from: tidla on 13 January 2013, 17:16:57
I've never known a windy capable of undoing 200 lb/ft+ nuts/bolts. :y
Broomies Mate
Quote from: Shackeng on 13 January 2013, 16:55:23
^^^^^^^^^  This is what I have done in the past.  :y
Marie
IS shocked   :o :o :o :o :o :o
you dont have a breaker bar  tut tut even i have a breaker bar  ;D ;D ;D ;D ;D
Muttly
was best on the landrover tdi lumps, place bar on crank bolt, end of bar against chassis and flick started..
It'll be rite
Shackeng
Quote from: Muttly on 13 January 2013, 18:25:37
^^^Yep, used that before also :y :y :y
Webby the Bear
Guffy, are you finding that the crank pulley just spins?
What I find at school is that if you use a long breaker bar (giving you more leverage and torque) it'll just spin the crank pulley.
If you get an impact gun there is no torque and all the twisting force is applied just to the nut alone.
Hope this helps  :y
RIP Paul Lovejoy
The wrong tools and poor technique, tut tut
Guinney1971
when we first did the crank pulley on my DeLorean (PRV-V6 engine), we had the 36mm socket, a breaker bar, length of scaffold pipe, and two (admitedly weedy) blokes pulling on the bar for all it was worth, whilst I sat in the car, gearstick held in 5th and literally standing on the brakes.
The bugger shifted in the end!!
However, as its now been off, when we had to replace the pulley last year (after the car got rear ended and it got damaged), it came off a piece of p***, as it hadnt been effectively 'welded' to the engine for 30yrs :)
Claire & Phill
Renault Grand Scenic 'Maxim' 1.9dCi 120
