Author Topic: External temperature sensor  (Read 2408 times)
Kate
  • Cornwall
    • Drives people mad
« on: 13 January 2013, 16:55:41 »
Hi everyone.
Just fitted my replacement front bumper today but can't find the external temp sensor which also needs replacing. Does anyone know where it is located?
It wasn't attached to the old bumper and we couldn't see it anywhere around the front of the car with the bumper removed.
We found one wire which wasn't connected to anything but we thought that might be for the front fog lights as it had 4 connections and the front fog light connectors are missing.
Any ideas?
Many thanks. :-* :-* :-* :y
Re: External temperature sensor
« Reply #1 on: 13 January 2013, 17:10:07 »
« Reply #2 on: 13 January 2013, 17:15:39 »
Youve just reminded me kate that I said I would send you a pic of the location.I forgot. :-[
Will try and take a pic tomorrow. Also,I may have a sensor and foglight connector plugs.Will have a look tomorrow and if I can find them,will send them to you. :y
Anything else you need relating to the bumper let me know and if I have it I will send it.
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #3 on: 13 January 2013, 17:41:16 »
Hi everyone.
Any ideas?
Have you looked around the area carefully, it is only the size of a finger end, and may have become detached as you took the bumper off?
Kate
  • Cornwall
    • Drives people mad
« Reply #4 on: 13 January 2013, 18:09:52 »
Many thanks Albs. You're the best! :-* :-* :-*
I don't know if there is wiring missing or not.
« Reply #5 on: 13 January 2013, 18:10:57 »
If I can find a sensor and the wiring plug I will send both. :y
« Reply #6 on: 13 January 2013, 18:13:31 »
The loom is part of the fog light loom, it plugs in on the passenger side and runs across the bumper, the temp sensor is located in the centre of the bumper
« Reply #7 on: 13 January 2013, 18:17:54 »
I think I should have the loom somewhere,but cant be sure until I check my stock tip all the boxes of crap out and have a look. ;D
Kate
  • Cornwall
    • Drives people mad
« Reply #8 on: 13 January 2013, 20:07:26 »
Thanks for all the help. :y
I've just had a look at the old bumper and I'm guessing that the sensor is missing and it looks like the wiring is missing too.
All I found was a wire with 4 bare terminals dangling.
I've no idea what to do next as I've got to fit a new temp sensor and there's no wiring for it.
There is no wiring for the fog lights either. ???
« Reply #9 on: 13 January 2013, 20:46:52 »
Leave it with me for the moment.Hopefully I will have the wiring and plugs etc to help get it all working. :y
Kate
  • Cornwall
    • Drives people mad
« Reply #10 on: 13 January 2013, 20:53:08 »
Thanks so much Albs! :y :-*
« Reply #11 on: 14 January 2013, 10:09:10 »
As EP has hinted probably simplest to replace the loom from the plug above the horns :y
It only goes to the fog lights and the temp sensor iirc  ::) and will (hopefully) remove any unidentified wiring/plugs :y
« Reply #12 on: 14 January 2013, 15:45:53 »
Found the sensor and the loom,which is good news. Bad news is the loom has been chopped through,could possibly be repaired,but might be less messing around if someone else has one lying around they could donate ?
Kate
  • Cornwall
    • Drives people mad
« Reply #13 on: 14 January 2013, 16:20:59 »
I'll pay for it even! :-* :-* :-*
