Author Topic: Compression Test Kit...this one ok?  (Read 2087 times)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« on: 13 January 2013, 19:14:30 »
http://www.ebay.co.uk/itm/CT955-BRAND-NEW-SEALEY-6-PIECE-PETROL-ENGINE-COMPRESSION-TESTER-KIT-/260911473502?pt=LH_DefaultDomain_3&hash=item3cbf89235e
Not many 6-piece kits available it seems but after a bit of hunting this one is the most complete I could fine. I'm thinking the Omega will take the 14mm adapter? Do you agree?
RIP Paul Lovejoy
Re: Compression Test Kit...this one ok?
« Reply #1 on: 13 January 2013, 19:40:17 »
That should do nicely. :y
Webby the Bear
  • Northampton
« Reply #2 on: 13 January 2013, 19:43:15 »
NOOOOOICE! Cheers Albus.... any idea what those two things are for though....  ???
RIP Paul Lovejoy
« Reply #3 on: 13 January 2013, 19:45:07 »
They may be push in adapters for unmusual size plug holes where the threaded adapters wont fit ? Not sure tbh.
Webby the Bear
  • Northampton
« Reply #4 on: 13 January 2013, 19:52:00 »
was thinking that too. oh well ill purchase in a week and get some results up  :y
cheers albs
RIP Paul Lovejoy
tidla
  • solihull
« Reply #5 on: 13 January 2013, 21:07:52 »
Webby the Bear
  • Northampton
« Reply #6 on: 13 January 2013, 21:17:20 »
A cylinder tester is a much more useful tool.
http://www.ebay.co.uk/itm/Sealey-Tools-VSE2020-Cylinder-Piston-Leak-Leakage-Pressure-Tester-Head-Gasket-/360423720949?pt=UK_Diagnostic_Tools_Equipment&hash=item53eaed87f5
Compression testers are cheap enough and a good start point.
Completely agree mate. You can find out exactly what and where the leakage is.
Only trouble being is you have to hook them up to shop air or compressed air tank.... just extra expense when I only really want to confirm if there is a problem or not  :y
HAVING SAID THAT... if I bought the compressed air tank I could purchase (in the future) a windy gun  :) :) :) :)
RIP Paul Lovejoy
the alarming man
  • medway kent
    • disco V8
« Reply #7 on: 13 January 2013, 22:41:18 »
a couple of months back a classic mag (practical classics i think ) done a test on the sealey compression  tester and it come out as their top buy and the price you have found it at is £15 cheaper than they list :y
« Reply #8 on: 13 January 2013, 22:56:12 »
OK  ... I'll bite...  :(
So, why is it called a "6 piece kit" ... when I count 8 items in the box ???
« Reply #9 on: 13 January 2013, 23:13:11 »
6 adapters I suppose.
Webby the Bear
  • Northampton
« Reply #10 on: 14 January 2013, 17:44:04 »
RIP Paul Lovejoy
