Author Topic: Auto Gearbox  (Read 2194 times)
Renaissance
  • Durham
    • Omega 2.2 Sport estate
Auto Gearbox
« on: 14 January 2013, 12:12:20 »
The auto gearbox on my 2.2 is a bit reluctant (occasionally) to change up especially when either cold or pulling away from a stopped position i.e. roundabout or junction. It is fine once it has done the initial up change and drives great up and down the box until you stop again. The oil etc has been changed so I was wondering if it could be a software issue? Any ideas? The local Vauxhall dealer wants £60+ just to check the software is up to date.
Re: Auto Gearbox
« Reply #1 on: 14 January 2013, 13:25:14 »
It intentionally delays the upshifts when cold to warm the cats up quicker.  :y
Re: Auto Gearbox
« Reply #2 on: 14 January 2013, 16:43:59 »
Agree with Kevin... but it should only really delay the very first gearchange from cold - if it's still doing that a few minutes into your trip, something isn't right.
In terms of a software update, I wouldn't recomment it at this stage. I would just get the fault codes read and see if there are any telltales there. I wouldn't be upgrading any firmwhere while there is still a known issue - as it could mask it / make diagnosis more difficult.
Ultimately, it won't be a software 'issue' as it's worked fine for years on that software from the factory. The update simply adds some refinement and improvements - it won't cure any faults.
Hope this helps :y
gibby
  • braintree
Re: Auto Gearbox
« Reply #3 on: 14 January 2013, 22:07:29 »
That sounds like cam sensor to me. I had the same probs on my 2.2 some few months ago. And the problem disappeared after changing the sensor.  :y
Renaissance
  • Durham
Re: Auto Gearbox
« Reply #4 on: 16 January 2013, 17:56:47 »
Thanks, makes sense I will did a bit deeper
Hope this helps :y
Renaissance
  • Durham
Re: Auto Gearbox
« Reply #5 on: 16 January 2013, 17:59:12 »
OK thanks will give that a try. Just driven from Moffat in Scotland to Durham and it only did it once, the rest of the time it was fine.
gibby
  • braintree
Re: Auto Gearbox
« Reply #6 on: 17 January 2013, 18:57:34 »
Usually it will drive normal after warming up when its a camshaft sensor problem. Also it has to be a genuine one to solve the problem. Thanks
Re: Auto Gearbox
« Reply #7 on: 17 January 2013, 19:16:00 »
Before buying a sensor, get the codes read. Many things can cause this.
Renaissance
  • Durham
Re: Auto Gearbox
« Reply #8 on: 17 January 2013, 21:24:28 »
Ok thank you for your help
